Old 07-15-2010, 02:45 AM   #1
pwa8383
pwa8383 is on a distinguished road
Default ignition off - rear lights stay on
1987 Toyota Supra (non-turbo) - After jump starting my car, rear lights stayed on after turning off ignition. Replaced bad alternator & battery, rear lights still stayed on. Removed relays from fuse panels, rear lights still on. Had to disconnect battery to turn off. Please advise?
pwa8383 is offline   Reply With Quote
Old 09-02-2010, 04:03 AM   #2
rob87
rob87 is on a distinguished road
is it the brake light or parking lights that are staying on? If it is the brake light then check the push button switch that the brake pedal touchs.
rob87 is offline   Reply With Quote
Old 09-02-2010, 07:10 AM   #3
Vacationtime247
Like he said, it's probably the switch at the brake pedal. Had the same problem with mine. Replaced the switch and now its fine. For a temporary fix, just unplug it until you can replace it.
VT247
Old 09-02-2010, 09:20 AM   #4
Busted Knuckles
Busted Knuckles's Avatar
I had the same problem with my '88. Turns out it was not the switch, but the hole they put on the switch tab to secure the rubber pad (that rotted out) is the exact same size as the plunger on the switch! The plunger was sticking through the hole! I patched the hole by gluing a penny over the hole with JB Weld. It's been two years and all is well.
Old 09-02-2010, 09:55 AM   #5
btwilson86
Super Moderator
btwilson86's Avatar
Hopefully it goes without saying, but you obviously would want to plug it back in before you go driving it. Want to make sure all the other drivers' know you're stopping.
Old 09-03-2010, 06:46 AM   #6
Vacationtime247
LMAO! You'd hope so! I meant unplug the switch so the brake lights wouldn't stay on all the time draining the battery. Certainly don't drive it without brake lights. Guess it doesn't do much good driving it around with your brake lights on all the time either. Matter of fact, you probably shouldn't drive it until it's fixed.
VT247
Old 09-04-2010, 04:05 PM   #7
pwa8383
Smile ignition off - rear lights stay on
Busted Knuckles had the correct repair solution. Replaced a $1 pad - lights went out. Thank you to all that posted a reply.
rear lights kylesupraturbo Non-Generation Specific Questions 0 01-19-2009 11:21 PM
