Old 09-02-2010, 04:12 AM   #1
rob87
rob87 is on a distinguished road
Default Parking light will not turn on.
Just looking for guidance here. My parking lights will not come on. Replaced teh light switch (on the steering column). checked fuses but not sure which one is for the parking lights.
All signal, driving, fog, brakes and headlights work.
Any help would be great here.
rob87 is offline   Reply With Quote
Old 09-02-2010, 04:34 AM   #2
15A "TAIL" fuse and the "Taillamp Relay" are what you need to check first... unless it's only the front or only the rear markers which are out.
Old 05-30-2011, 06:14 AM   #3
rob87
Default No tail light, accept when braking
So, I have all my lights working, side marker(front & rear), brake, headlights, signal (left and right) but not parking lights in the rear tail lights. Again everything turns on and works except the rear tail light. Any ideas??
Old 05-30-2011, 12:40 PM   #4
El Supracabras
El Supracabras's Avatar
If you have already checked what cre has recommended, and they check out ok, you may have a problem with corrosion in the rear of the car. Water gets in the hatch and tail light housings and corrodes the wiring, bulbs, sockets, sheet metal grounds, lamp failure module etc. Give it all a good look over, if you have a multi-meter or test lamp to use you should be able find where the voltage stops.
Old 05-30-2011, 01:56 PM   #5
rob87
Default ty
Thanks I will look around
Old 05-31-2011, 03:36 AM   #6
The front marker lights should not be affected if it's corrosion of the connectors in the rear or a blown Tail Lamp Failure module unless there is a MASSIVE short to ground, but then you'd be going through fuses non-stop.
Dome Lights btwilson86 MKIII Supra 6 04-03-2011 01:05 PM
MKIII Wilwood 12.9" Rear Brakes With Parking Brake ARZ Arizona Performance 0 08-25-2010 06:34 PM
check engine light & bulb light, what? nosuprayou MKIII Supra 2 12-19-2009 09:15 PM
light and power problem bigdoggbmx MKIII Supra 3 12-05-2006 07:00 PM
will parking brake light kill cruise? 88Supraboy MKIII Supra 5 03-01-2006 04:14 PM
