Old 08-27-2010, 03:55 AM   #1
kllswitch92
kllswitch92 is on a distinguished road
Default 1986.5 1987 Auto To Standard Conversion
Well I Had A 86.5 non turbo supra but unfortunately crashed it so I bought another one but it was auto and it was turbo. I Spoke To A Few People and they said the conversion would be no problem I Would just need to get everything from my other car after the whole swamp was made my turbo gave out i really don't know much about turbo or what could gone wrong can someone please help me I Don't know if it was the transmission that messed it up or if a hose just broke for the turbo?
kllswitch92 is offline   Reply With Quote
Old 08-27-2010, 04:13 AM   #2
well the NA transmission was "weaker" then the standard turbo transmission.
R154
  • First Gear: 3.250:1
  • Second Gear: 1.955:1
  • Third Gear: 1.310:1
  • Fourth Gear: 1.00:1
  • Fifth Gear: 0.753:1
but the NA and turbo automatic tranny the A034e are the same..
so swapping in a W58 really should of messed to much.
  • First Gear: 3.285:1
  • Second Gear: 1.894:1
  • Third Gear: 1.275:1
  • Fifth Gear: 0.783:1
  • Reverse: -3.768:1
Turbos do go out on a 20 year old car.. specially if there not maintained or people push too much boost with out proper precautions.
Old 08-27-2010, 04:29 AM   #3
kllswitch92
So it really shouldn't Be to much of a problem? Thanks Man Oh I Forgot To Mention That IT Did Have An Engine Swamp To A 91 turbo And IDK How To Tell The Difference From A 1jz To A 2jz motor but I didn't really think the engine swamp couldn've been part of the problem??
Old 08-27-2010, 03:33 PM   #4
erm the 91 7mgte with the w58 transmission had a 1jz in it?
lol id suggest getting the more robust transmission. anyhow ... with engine swaps there are still things "electronics" that need to be switched over.. like the ECU for example. engine harnesses for another.
what exactly happened to your turbo? most likely someone didn't rout a coolant line correctly and boom..
Old 08-29-2010, 02:39 AM   #5
MJG
MJG's Avatar
Personally, I would be interested in some details about the turbo "going out".
The transmission swap should not have been an attributor to the turbo failure.
Old 08-29-2010, 05:30 AM   #6
kllswitch92
I honestly don't know what happened to the turbo I'm not one to know much about that and I don't know to many shops around here that would be able to look into it. Some guy was telling me by converting the car I Pretty much F!#$ed Everything Up but others say it shouldn't be a problem that it might be a boost leak, ripped hose, worst case scenario that the turbo would need a rebuilt.
Old 08-29-2010, 08:36 PM   #7
Originally Posted by kllswitch92 View Post
Some guy was telling me by converting the car I Pretty much F!#$ed Everything Up but others say it shouldn't be a problem.
well if you took a non turbo motor and made it into a turbo (ed) motor then yea there is allot of things to do and do correctly. if you just "swapped" motors than its not so much labor intensive.
tell "some guy" to stfu.
erm. wost case scenario you have a catastrophic failure and your turbo explodes.
auto to standard conversion c&csupraowner MKIII Supra 1 08-01-2008 09:24 PM
Auto to Manual Conversion justin1642 MKIII Supra 9 09-18-2006 04:22 AM
How hard to do a Auto to manual conversion? lOnEstArMx250r Non-Generation Specific Questions 1 10-14-2005 08:14 PM
