Old 08-23-2010, 11:53 PM   #1
jcastro
Default ball joints
idk if its my ball joints. my car started making popping noises every time i would come to a stop and go on dips i checked every thing under and didn't find anything out of place besides a torn boot cover for my racknpion I told my friend to look at it wile i rolled and then braked. he said the tiers move at a weird motion back and forth. I am thinking its my ball joints what do you guys think
jcastro is offline   Reply With Quote
Old 08-24-2010, 12:41 AM   #2
Travis89Turbo
Travis89Turbo's Avatar
Definatly have symptoms of ball joint or possibly a strut. And ur friend watching under ur car while moving sounds dangerous I wouldnt recommend that at all. Easiest way to check ball joint is put it on a jack stand and grab the top and bottom of tire and see if u have any play. If u have any at all its a bad ball joint.
Keep your friends out from under your car
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 08-24-2010, 04:34 AM   #3
Brakes are a possibility as well. Any noises while moving at a steady slow pace? Does the noise show up regardless of brake pressure? Is the noise always a steady pattern?
I'd inspect ball joints and Brake components for signs of seizing or poor alignment.
Old 08-24-2010, 03:32 PM   #4
jcastro
hahah my friend was not under the car he was watching from the side as i rooled the car and then braked and yes the noise is a pattern it always pops twice like pop pop almost like a mest up strut mount except the noise comes from the bottom and the tires move back and forth
on a lighter note i at least got my ac going again thank god this 112 weather kills man
Old 08-24-2010, 04:11 PM   #5
Green7mgte
Supra Forum Moderator
there is a ball joint replacement guide in the faq. you can get a set (left and right front wheels) tie rod ends + ball joints off ebay for about 100.
Think someone on here tested it and proved ok. but I heard mixed things about oem ebay parts.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 08-25-2010, 04:15 PM   #6
jcastro
thanks man ill give it a try and see wut happens my friend build a turbo 86 325 basically off ebay and it came out good and for 100 bucks you cant beet it
Lower Ball Joints - Checking here first Grandavi MKIII Supra 3 09-20-2008 04:04 AM
Tie Rods & Ball Joints mrnickleye MKIII FAQ 1 03-10-2007 04:50 AM
Tie Rod End and Ball Joints!! KrnSupra2307 MKIII Supra 6 02-27-2007 11:01 PM
