Old 08-16-2010, 03:47 AM   #1
Supra Saiyan
Supra Saiyan's Avatar
Supra Saiyan is on a distinguished road
Default CPS plug GONE!
1988 turbo A/T
lol so its gone.. Burned up.. Cam position sensor plug.. Both sides.. So I got a no start from all of this... I looked for a good long time between Google and here. Lol, found a few unanswered post. Ugh~!
So, can someone tell me where I can get the plugs. Possibly even a little of the wire to help extend the range (Correct size too). Lastly, which wire goes into each plug piece.
TSRM has me scrambling for the full info. No help rather.. Anyone have the answer. I know this problem is not irregular.
Supra Saiyan is offline   Reply With Quote
Old 08-16-2010, 04:21 AM   #2
Replacement pigtails or just connectors and pins are available from Toyota... well, a lot have been discontinued but quite a few are still available as they were used on other cars. The pre89 N/A's connector was the same as the pre89 (and I think 89+) CPS.... 89+ N/A used a different connector.
Old 08-16-2010, 04:57 AM   #3
Supra Saiyan
Well I guess I'm off to check with Toyota tomorrow.. Ugh! Wish me luck..
Old 08-16-2010, 05:04 AM   #4
Supra Saiyan
Well, since myn was burned up and research is all i have done to understand what I am looking for.. i have no actually seen the part I search. This is claimed to be a 7M-GTE CPS Connector Replacement..
However. It looks like it wont work from my understanding. Is this the 89+ connector? I thought I would be looking for a green plug or somthing that looks like the one in the picture with the entire cps in it. Please let me know..
CPS connector replacment
http://www.xpressbasehosting.com/dri...33&iViewFlag=1
CPS whole 1
http://www.jblmk3.com/cars/jblmk3_gr..._info/cps2.jpg
CPS whole 2/3 (click on ebay pic to enlarge)
http://cgi.ebay.com/ebaymotors/ws/eB...d=260650152712
Old 08-18-2010, 03:14 AM   #5
Supra Saiyan
Default Solution
Well, screw the plugs.. They are being wired as one wire!
Old 08-18-2010, 03:22 AM   #6
Not still available? I'd just find someone who has an old one the would be willing to cut the plug off of.... that or clip off both of yours and install another weatherproof, high temp 4 pin connector.... Napa has them sometimes... usually for GM applications IIRC. Whatever you do, put a connector in there.
Old 08-18-2010, 03:27 AM   #7
Supra Saiyan
Well, it was just finished up nowish~.. I couldn't find one, or rather didn't want to wait to find someone to buy one from that didn't want to sell me the whole darn CPS.. What disadvantage am I at. Will I lose any performance.. From my understanding it's none.. What am I not seeing that you see? Thanks for the help...
Edit - Err, besides if my CPS goes down needing the next one wired in..
Stripped plug! batmmannn MKIII Supra 8 05-18-2010 11:29 PM
radiator drain plug 2Fast2Furious MKIII Supra 19 01-02-2010 12:41 AM
supra ecu plug help please nzskate MKIV Supra 3 11-18-2009 01:52 AM
Transmission filler plug elsleepster Non-Generation Specific Questions 3 11-02-2008 04:44 PM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
