Old 08-13-2010, 03:02 AM   #1
91ma70
91ma70's Avatar
91ma70 is on a distinguished road
Default Swap in LSD-Difficulty?
I found a parting out supra near my place and the guy still has the LSD available; its from a 87 NA. So my question is it going to be difficult to swap in the LSD? Will i have to remove the rear sub-frame? Secondly, what should be a good price for the LSD, i want to now the range before negotiating on his terms.
91ma70 is offline   Reply With Quote
Old 08-13-2010, 01:12 PM   #2
if it works or not is another story. open it up look at the spider gears and if there is shavings. does it have a blue oily lookin tint on the gears.
Old 08-13-2010, 07:39 PM   #3
Green7mgte
Supra Forum Moderator
bout 10 bucks a hit if its any decent..
ah ha..
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 08-13-2010, 08:18 PM   #4
91ma70
91ma70's Avatar
i haven't had a chance to go look yet, haha I wanted a quick overview of what to look for first. so im guessing that there no way tell unless you open up the carrier cover and look for damage and blue tint oil?
Old 08-14-2010, 12:01 AM   #5
you misunderstand.
the metal itself will have an oily bluish look if it has seen heat, due to under lubrication.
i wouldnt give any more than 50 dollers for a used diff. period.
Old 08-14-2010, 02:28 AM   #6
91ma70
91ma70's Avatar
okay, i see thanks ill definitely take your recommendations to consideration thanks
Old 08-15-2010, 03:53 PM   #7
i would also, flush out the diff, and make sure to be using the right fluids for a Limited Slip Differential.
7mgte swap vs 1jz swap Supra Saiyan MKIII Supra 15 04-24-2012 02:58 AM
Year to Year MGE Swap changes Mr.Bojangles MKIII Supra 6 01-10-2008 07:44 PM
JDM swap, now engine light, please help christutecky MKIII Supra 0 08-10-2007 07:49 PM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
MKIV auto to manual swap?? awd4g63tsi MKIV Supra 0 10-24-2005 08:46 PM
