Old 08-14-2010, 03:21 AM   #11
its a 20 year old car.. and people drive the crap out of them.. do yourself a favor and replace all the coolant hoses at the same time.. not one at a time when they blow like i did...
Old 08-18-2010, 03:56 AM   #12
vbryanv
vbryanv is on a distinguished road
Angry MORE PROBLEMS egr?
ok so now i come to find out i need a radiator. gonna have to wait till next month on that one.
but i want to fix the egr problem.... by deleting it.
my only question is i read people thinking they would have to take the head off in order to intall the plates and my leak is on the block on the intake side?? can i just block the intake side of the block and the intake mainfold.
is there anything on the back of the head that i have to block?
vbryanv is offline   Reply With Quote
Old 08-18-2010, 05:07 AM   #13
i wouldnt delete the egr.. it does your car good. like milk for the exhaust system. makes your body cold and grow up strong..
Old 08-19-2010, 12:03 AM   #14
afsvanderveen
afsvanderveen is on a distinguished road
u may have checked already but check the thermostat. If its stuck closed it will cause an overheating problem, then that leads to leaks and so on. Wrong temp thermostat can do the same thing if its really hot where you are.also i would suggest a system flush in case there are any blockages. As the coolant system like to build scale and will cause havock if left to long.One more thing, unfortunately in our cars if you have had a overheating problem and its been serious, chances are you have a bhd
afsvanderveen is offline   Reply With Quote
Old 08-19-2010, 01:13 AM   #15
Test the thermostat in a pot of water on the stove and use a thermometer to make sure it's opening at the right temp. Details are in the TSRM.
Old 08-19-2010, 02:23 AM   #16
Burt21
Burt21 is on a distinguished road
Hmm quite the pickle you have there. Having your egr hooked up will definitely help cool things down in your cylinders and take care a pesky nox. Are you having any probs with your cooling fans at all?
Burt21 is offline   Reply With Quote
Old 08-19-2010, 03:33 AM   #17
off topic..
lima ohio.. whats up man! canton here!
on topic.
overheating issues.. rad cap. thermostat.. leaking lines.. bhg + many more.
start at the top and work your way down.
Old 08-19-2010, 03:36 AM   #18
runs from the rear up to the TB, out of the TB to the ISCV, from the ISCV back into the block.
the neck bone connected to the... shoulder bone.. shoulder bone connected to the.....
has this been checked up on?
Old 08-19-2010, 08:18 PM   #19
gloreboy89
gloreboy89's Avatar
gloreboy89 is on a distinguished road
o man why does it have to be so simular to my problem? lol About a month ago I bought my first car. An '88 supra with a 7mge engine. anyway it overheated on me on my 2hr drive back home and i(my mechanic, i gave up) found out the radiator wasn't pumping out enough coolant at higher rpms. so I switched out the radiator with a all metal one and changed the clutch fan for added safety. As of now i have no heating problems.
gloreboy89 is offline   Reply With Quote
Help... my car is overheating suprra_girl MKIII FAQ 40 07-11-2010 06:51 AM
supra overheating quiky Non-Generation Specific Questions 4 09-09-2009 11:16 PM
2 Questions: 1 About Overheating, 1 About HeadUnit Adaptor V1P3R MKIII Supra 9 07-17-2007 05:26 AM
car overheating marc MKIII Supra 11 06-30-2006 05:55 AM
Need Help, Overheating Problems MDellboy420 MKIII Supra 9 12-19-2005 06:46 AM
