Old 08-08-2010, 08:49 PM   #11
Supra Saiyan
Supra Saiyan's Avatar
another idea if you dont want a box in your engine bay, just route a pipe down under the headlight behind the fog light near the road. fresh cold clean air and a non cluttered engine bay..
Would it be better to combine both ideas?
Heat shield/Box
Pipe from below coming up
Old 08-08-2010, 09:22 PM   #12
a heat shield and box is the same idea. anything to keep the HOT air from your air filter.
Id suggest placing your air filter down were the snorkel for the stock air box is by running a pipe from the maf to the air filter and than just blocking it off were the original box used to be. have a smart clean engine bay with cool air. make sure you put one on the side were the rad is.. block the rad hot air too..
thats what im doing once i get my air filter
Old 08-11-2010, 05:46 AM   #13
Supra Saiyan
I have been researching filtration, gains, etc.. Just for some solid proof on WHAT filter to choose.. I simply want to combine the best PROVEN filter with some of the ideas we have come up with here.
Check this out.. My.. PROOF..! (Don't kill me if you have seen this before)
http://www.mkiv.com/techarticles/filters_test/2/
Old 08-11-2010, 09:32 PM   #14
there are ton of air filter posts around here.. some in the faq i think.. aem dry flow filter works just as well as the leading brands for less cost.
oh and if anyone is using one of those honeycomb air filters.. im going to kick you in the junk..
Old 08-12-2010, 01:46 AM   #15
Man that review/test is OLD.... A lot of new stuff on the market and sadly only one or two products which are any better.
Old 08-12-2010, 01:49 AM   #16
Supra Saiyan
What~! Which products? Any proof? Please share.. ::Cre's knowledge::
Old 08-12-2010, 02:09 AM   #17
There are some tests out there where they do a more scientific test... I'll look for the book mark. They used MEASURED particulate which is all a known size and suck that through the filters while measuring the difference in air pressure outside the filter vs inside (using a device known as a differential manometer) Amsoil and AEM were the top dogs, IIRC. I don't think Apex'i was included. IMO Apex'i, AEM and Amsoil are all excellent choices... I lean toward AEM just because I switched to those before I found out about Amsoil's offerings. I switched from Apex'i when my old one got damaged and I found I could get the AEM for half as much.
Old 08-12-2010, 02:50 AM   #18
MJG
MJG's Avatar
I replaced the K&N FIPK with an AEM filter. The AEM has proven to be an outstanding choice.
I have had the AEM for over three years now. It is very easy to service. The filter shows no signs of wear from the numerous times I have cleaned it. The intake throat has no detectible contamination residue in it, when I run a rag around the inside of the pipe.
The K&N always had an oil residue and some slight detectable grit mixed in.
Old 08-12-2010, 03:00 AM   #19
There's no doubt about K&N's air filter sucking (pun intended)...
Here's a fun experiment for someone: Buy a differential manometer (hint: try searching ebay for magnehelic ). Now connect the filter to a vacuum and connect the hose to a nipple in that pipe. Now build a box around the filter and give it an inlet pipe the same size as the outlet. Add a nipple and connect the other gauge hose to that nipple... now turn on the vacuum or engine and record the pressure drop across the filter. Now try the next filter and record it, and so on. This and the minimum particulate size are the two important qualities behind a good filter... personally I'll take something with a tiny bit more restriction if my engine will last longer, but with the three I listed the pressure drop I've seen reported is minimal anyway.
What is the average age of the MKIII driver? colin172 MKIII Supra 280 10-24-2011 02:14 AM
3" exhaust/2.5" wit not cats Hp Gains? supraman121 MKIII Supra 0 08-20-2007 06:09 AM
How much is this Supra worth? Whats the average? GTE89 MKIII Supra 6 12-12-2006 04:56 AM
Average Mileage of a MK3?? h8z2luze MKIII Supra 37 11-05-2006 02:07 PM
