Old 07-25-2010, 07:40 PM   #1
goldenboy
goldenboy is on a distinguished road
Default Stuck!
Hey Ya'll,
I recently got a 87 supra turboed with a blown head gasket. I started working on it and everything is out of the way of the engine and I cannot get the transmission to let go of the engine. I can get a gap between the motor and tansmission of probably and inch but then itll just slide back together. A friend told me to make sure the clutch is engaged.Also the manual directions have beenfollowed to a t. Anybody got any ideas please help.
thanks
goldenboy is offline   Reply With Quote
Old 07-26-2010, 02:36 PM   #2
it's easiest to pull with the transmission attached... if you think pulling it apart in the car is bad, you might want to start thinking about how bad putting it back in is going to be.
cant offer much other advice than make sure the transmission is being supported at the same angle and speedo cable is disconnected... same for the wiring.
Old 07-26-2010, 04:22 PM   #3
goldenboy
I was thinking about that. Woah fun. Thanks!
Tags
engine
idle stuck 84supradude MKII Supra 2 04-08-2009 02:49 AM
Wastegate stuck open mkiiisupra MKIII Supra 6 09-17-2007 02:09 AM
Stuck Lifter.. or so i think OmeGa MKIII Supra 16 07-17-2007 08:37 PM
HELP!!! My Hood is stuck closed!! opeth_07 Exterior , Interior, and Detailing 6 07-31-2006 06:02 PM
HELP!!! My Hood is stuck closed!! opeth_07 MKIII Supra 4 03-30-2006 12:55 PM
