Old 07-21-2010, 06:11 AM   #1
yongai27
yongai27 is on a distinguished road
Default Compression help
Hi Im kinda a newb...what is the compression test for an NA mk3 supra supposed to be around?
yongai27 is offline   Reply With Quote
Old 07-23-2010, 12:32 AM   #2
the answers you seek may lye within this vary forum.
all you need to do is search.
Old 07-23-2010, 12:41 AM   #3
Just posting "search" as an answer cause search results for queries to come up with nothing but threads that are never answered. If you want to ask someone to please start using the search feature, fine, but at least post some suggested search terms and a link or two.
OP, here you go:
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=20
Old 07-23-2010, 12:46 AM   #4
yes but then your doing the work for them.
and i sometimes leave a helpfull link or 2, depends.
Old 07-23-2010, 12:53 AM   #5
Don't post if you're not going to post anything helpful.... I've seen 10 page threads on other sites where NOT ONE person answered the OPs question.... which happened to be the same question I needed an answer to. They actually ended up having to take the search engine down because it couldn't take the load.
And it's not a suggestion.
Old 07-23-2010, 12:59 AM   #6
well no soup for you...
Edit: and yes i know im a dick...
Old 07-23-2010, 01:40 AM   #7
yongai27
ahhh thanks. Canadian, i will agree with you, i should have searched it first. But it probably would have just easier for you just to have answered the question than type those responses LOL. Unless u have so much hate in you that u would spend extra energy just to spite someone...
Old 07-23-2010, 02:04 AM   #8
as long as you learned to use search it was much easier this way.
Old 07-23-2010, 03:23 PM   #9
yongai27
i just said that..
Old 07-23-2010, 04:26 PM   #10
MA70-3.0GT
MA70-3.0GT's Avatar
Oh dear, I spend a couple of months away recovering & come back to this. Now now children, play nicely!
Standard MGE compression is 156psi (GTE is 142), minimum 128psi, diff. between cyls is 14psi (GE & GTE).
the tsrm book is a godsend to those "on the learn" about supras... http://www.cygnusx1.net/Supra/Librar...ection=EM&P=20
There...
Right, gotta get back downstairs for tea. If I don't reply to anything else tonight it's cause I'm too knackered to get upstairs again.
Cylinder Compression Values SupraSleuth MKIII Supra 6 08-17-2009 11:53 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
looking at a 90 turbo with compression problems jtitzer56 MKIII Supra 1 09-23-2006 05:27 PM
Compression Question Intenseneal MKIII Supra 5 08-15-2005 10:27 AM
