Old 07-01-2010, 02:57 PM   #1
TehEl1te
TehEl1te's Avatar
TehEl1te is on a distinguished road
Default Question about Turbo exhaust on NA
Hey guys. I know for a fact this topic has to have been covered on here at some point but i simply can't find it... I found a few threads on what exhausts are best but I can't pinpoint the question I need answered. Please be patient with me
I got a 1990 NA Supra from Ohio (they don't have emissions there) and I need to get it inspected here in PA. I need exhaust to pass inspection. I so luckily found a person who has stock exhaust (the whole thing) from his Turbo model. Will the catback (including the cat) bolt up to a NA car? I know people will put turbo exhausts on their NAs sometimes but will the stock catalytic converter all the way to the muffler fit on my NA? If so I am saved... Let me know guys! I apologize for my noobery
TehEl1te is offline   Reply With Quote
Old 07-01-2010, 03:59 PM   #2
Green7mgte
Supra Forum Moderator
the NA dosnt have the same downpipe as the turbo.. so if your talking from second cat back then yes.. hell as long as it fits.. if not buy an adapter flange.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 07-01-2010, 04:01 PM   #3
TehEl1te
TehEl1te's Avatar
Thanks green for not hating on me. Haha
see how the exhaust is seperated at the cat here.
http://images.craigslist.org/3n93k23...c483041168.jpg
I need that cat and then the cat back. Make sense? Would that go on my NA? It is the stock exhaust from a turbo model MKIII
Old 07-01-2010, 04:03 PM   #4
Green7mgte
the shorter bended piece won't work.. thats for a turbo, its called the downpipe. that is different on an NA.. as for the (the long piece attached to the muffler) I would think that would work fine.. if it dosnt fit.. buy an adapter flange. cut the second cat off the down pipe and attach it to the longer one..
Supra FAQ
Supra MKIII FAQ
Old 07-01-2010, 04:05 PM   #5
TehEl1te
TehEl1te's Avatar
Yeah, that downpipe attached to the cat I don't want. I know that much So I can take that cat, the pipe with the resonator, and the muffler and it will fit?
Old 07-01-2010, 04:07 PM   #6
Green7mgte
yea.. if not get an adapter flange.. all depending on what remaining pipe you have on your NA.. if your NA pipe is smaller go get a flange that fits. problem solved.
Supra FAQ
Supra MKIII FAQ
Old 07-01-2010, 04:07 PM   #7
TehEl1te
TehEl1te's Avatar
Thanks Green. You were a huge help here!
Old 07-01-2010, 04:08 PM   #8
Green7mgte
ask your budy with the peiced out turbo if he has an accordion hose.
Supra FAQ
Supra MKIII FAQ
Old 07-01-2010, 04:45 PM   #9
907mge
907mge's Avatar
The cat and cat back are the same on turbo and non turbo the only difference is the downpipe. So as long as no one has welded any thing together you should just need new gaskets. Use penetrating fluid and let it sit to help break the bolts loose.
Old 07-01-2010, 05:38 PM   #10
TehEl1te
TehEl1te's Avatar
YOu guys are champs. Thank you so much!
exhaust question (not in exhaust faq) sd88supra MKIII Supra 21 11-28-2006 10:52 PM
Turbo lag question. rnoswal MKIII Supra 6 02-12-2006 05:42 AM
