Old 06-19-2010, 12:15 AM   #1
2.5RHDsupra
2.5RHDsupra's Avatar
2.5RHDsupra is on a distinguished road
Default Ummm, I think i broke it...
Ok so my coilpack harness is broken, how the heck can i fix it,
any help will be greatly appreciated
ID:	3177   Click image for larger version
2.5RHDsupra is offline   Reply With Quote
Old 06-19-2010, 12:50 AM   #2
ochowdero
Default huh?
ima post a reply so more ppl can veiw lol.
uhm what broke,
i see a wire that came lose.
or something...
maybe a better picture?
Old 06-19-2010, 12:54 AM   #3
the coil pack that sits ontop of the spark plug broke off it looks like...
never worked on that engine before so I cant really comment.. pull one from a part car or have it ordered.. I would replace the hole thing tho, and not just the top
Old 06-19-2010, 12:54 AM   #4
batmmannn
batmmannn's Avatar
Default Connector
Looks like you broke a wire off your wiring harness, just splice in a new wire with the proper connector. Appears to be off the harness not the pack. Insulate the break with electrical tape or with a wire splice connector wrapped in electrical tape. That is if it is not a coil wire.
Old 06-19-2010, 05:12 AM   #5
2.5RHDsupra
Yeah the harness broke but one of the wires inside the harness is broken, not the actual wire, but the connector part, if that makes sense.
Old 06-19-2010, 05:25 AM   #6
turbonicsperformance
find the lock on the metal prong that goes into the connector (the piece your showing us) it will have a small lock or basically a pertruded piece of metal coming off of it just bend it out more and insert it back into the original plug and for extra strength add a dab of superglue to it ive done it a hundred times and have never had one fail a second time
Old 06-19-2010, 05:27 AM   #7
2.5RHDsupra
problem is, one of the two is broken!
oops i broke the headlight help supraluver4life MKIII Supra 13 12-22-2009 04:04 AM
Speedo cable broke. What next? Busted Knuckles MKIII Supra 5 10-25-2009 06:01 AM
Broke something.. and i dont know what it is. help. Kevin MKIII Supra 2 06-08-2009 12:10 PM
some f*ck broke my passenger window D_Train MKIII Supra 9 04-29-2007 09:07 PM
my 86 broke pittsupra MKII Supra 2 06-05-2006 11:42 AM
