Old 06-15-2010, 10:29 PM   #1
bryanf89
Default Should the wastegate vacuum line look like this?
if so then i routed it wrong, can that be my problem to the turbo pressure dilemma?
fyi; that isnt my car
Old 06-16-2010, 02:25 AM   #2
bryanf89
cmon guys...i know you know this
Old 06-16-2010, 03:44 AM   #3
turbonicsperformance
looks correct your wastegate runs off the fitting on the turbo itself not an engine vac
Old 06-16-2010, 03:49 AM   #4
bryanf89
i put the fitting to the small nipple on the bottom of accordion hose
Old 06-16-2010, 04:19 AM   #5
Then it's not ran properly. The accordion hose does not build up boost pressure, so there's nothing to open the wastegate with.
Old 06-16-2010, 12:08 PM   #6
bryanf89
hmm guys i may have found my problem....ill report back with that
Where is this vacuum line saposed to connect to? mkiiisupra MKIII Supra 15 07-15-2010 05:15 AM
vacuum line kits CanadianBak'inSupra MKII Supra 1 04-21-2010 02:34 AM
Is this a vacuum line? Paul_NJ MKIII Supra 3 04-18-2009 10:32 PM
Vacuum line routing to HKS SSQV? mkiiisupra MKIII Supra 8 02-06-2008 05:29 AM
Vacuum Line Deletion? Bullz_EyE MKIII Supra 1 12-24-2005 06:37 PM
