Old 06-06-2010, 03:18 AM   #1
Sonyps307
Default HID kit
Hey guy I installed a HID kit and now my car thinks that I have my high beams on so my fog light won't come on. I know they still work because when I turn on the light on the fog lights turn on faster then the headlights but soon as they come on the fogs turn off is there a way to by pass this maybe
Old 06-06-2010, 03:47 AM   #2
Green7mgte
Supra Forum Moderator
did you put your hids on the high beam?
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 06-06-2010, 03:58 AM   #3
Sonyps307
Well I got bio-beam and it's a plug and play one so the plug looks like the back of a h4 bulb and its high/low hids but I don't have the high beam part hooked up and it did it with and without it hooked up. On the oem head light wire there are 3 wires which one is the high beam maybe I can cut it and that will fix it
Old 06-07-2010, 02:18 AM   #4
Green7mgte
not recommended.
hm I have to dig up my old HID info links.
what happens when you use your high beams?
you could try this
http://www.supraforums.com/forum/sho...d.php?t=169197
but i wouldnt recommend it either
Supra FAQ
Supra MKIII FAQ
Old 06-07-2010, 05:36 AM   #5
Sonyps307
Nothing the high beam blue light inside doesn't come on to
Old 06-30-2010, 02:54 AM   #6
2genfun
2genfun is on a distinguished road
i just got the same problem...i think its got something to do with the full curcuit not being connected. im gonna work on it tomorrow at work and ill see what i can discover
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
2genfun is offline   Reply With Quote
Old 06-30-2010, 03:17 PM   #7
Crazysupra
Crazysupra is on a distinguished road
Default Hid
I have the HID's. My fog lights work like normal but the blue light on dash stopped working. I bought the Bi-HID high/low both work with HID.
Crazysupra is offline   Reply With Quote
Old 10-21-2011, 10:21 PM   #8
gen.boy
gen.boy is on a distinguished road
have you found the problem?
gen.boy is offline   Reply With Quote
Old 10-22-2011, 12:20 AM   #9
The high beam indicator is part of the actual high beam circuit. The stock high beams won't turn on if that lamp is removed and vice versa.
http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=060
I suspect that in order to get the indicator working with an after market setup (whether a rewire such as recommended by Daniel Stern or a full HID kit) you'll need to set up the system to use the Red-Blue Stripe wire as ground instead of the chassis or other ground location.
