Old 05-24-2010, 11:01 PM   #1
vbryanv
vbryanv is on a distinguished road
Default Freeze out plug gone while driving???
so this sat. while pushing the car a little... my block blew a freeze out plug. wtf????? y???? damn??? HAD TO TAKE THE EXHAUST MAINFOLD OUT IN ORDER TO CHANGE. EVERY SINGLE BOLT CAME OUT WITH THREADS AND NOW I GOT TO HELI COIL. DAMN!!!! has anyone every seen this with the freeze out plug before. wondering if my pressure is too high and should i change the rad cap??
vbryanv is offline   Reply With Quote
Old 05-25-2010, 01:08 PM   #2
Test the radiator cap. Should open at 13psi. Do keep in mind that if you replace it you risk the new one being off as well, they're not made with the precision they deserve, test 'em before you buy it.
Old 05-25-2010, 03:12 PM   #3
vbryanv
replaced plug fit pretty tight. inserted with silicone. was thinking about using jb weld now around the edge? now in the process or heli-coil
Old 05-26-2010, 06:30 PM   #4
be careful when drilling and re tapping. its a very slow and precision based task.
Old 05-27-2010, 10:09 PM   #5
vbryanv
just finished up. had a little problem getting 2 of the heli-coils in. tried for hours, before deciding to just run a tap and installing a 12x1.25 bolt instead of 10x1.25 everything worked out good. i haven't been able to drive to far yet because the intercooler hose on the bottom of the turbo fell off and i don't want to drive like that. probably gonna get it done tomorrow.
Stripped plug! batmmannn MKIII Supra 8 05-18-2010 11:29 PM
freeze plug thakiller009 MKIII Supra 7 11-22-2009 01:31 PM
Need Serious Help - Car driving me crazy cgreiner MKIII Supra 15 05-10-2009 09:30 PM
Driving Bacwards in Australia mrnickleye Off Topic Forum 5 10-09-2006 04:42 PM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
