Old 05-21-2010, 03:14 AM   #1
kadinz
kadinz is on a distinguished road
Default okay so..
cleaned the TB and got the bitch runnin, now i got another problem.. sounds like theres a knock, you can hear it more when inside the car, can barely notice it outside the car when its running..i'm not sure what to make of this
when my friends mustangs MAF went out it started to sound like it was knocking, could this be it??
-kadinz
sorry.......meant to make the title, got a knock now.
kadinz is offline   Reply With Quote
Old 05-21-2010, 03:41 AM   #2
batmmannn
batmmannn's Avatar
Default Knocks
Could be bad crank bearings. Usually is.
Old 05-21-2010, 03:48 AM   #3
kadinz
damnit! i just got this engine replaced!!!!! how long do you think i have?
Old 05-21-2010, 03:54 AM   #4
batmmannn
batmmannn's Avatar
Default Knock
Take a video of it and upload it to you tube so we can all check it out. Where did you get the motor? If its a dead knock like on wood and it is coming from your block it usually means bearings Is it coming from the head or the bottom? Is yours a stick or auto?
Old 05-21-2010, 03:59 AM   #5
kadinz
auto, the sound kinda aligns with the exhaust, do you know what i mean? like i kinda got an exhaust leak and it sounds like its circulating with the exhaust.
Old 05-21-2010, 04:06 AM   #6
batmmannn
batmmannn's Avatar
Default exhaust leak
Well if it is from the exhaust yes they can make noise but it is usually not a knock. Did you install the engine? Could be the manifold gaskets. Do you feel any air pushing where you hear the sound? Usually if it is so compressed that it could sound like a knock it would be a small leak in the gaskets or a hole in the header pipe. Check were the exhaust manifold meets the first pipe there is a gasket that goes in there. See if you have air escaping there. Have you looked all this over? Take a very large screwdriver put one end on the place you hear it from and the other against your ear and see if you can trace it as being in the manifold or in the block. If it doesn't sound like a woodblock then it's probably exhaust.
Old 05-21-2010, 04:14 AM   #7
kadinz
idk, it sounds bad..the engine runs good and everything, it just...sounds bad, i dont wanna run it or drive it! ill check the exhaust tomorrow..see if it's that, maybe it spring a leak from all the gas being pushed through there when it started efffffing up!
Old 05-21-2010, 04:19 AM   #8
batmmannn
batmmannn's Avatar
Default Ok
Hope for an exhaust leak. Bad Bearings means total tear down or replace. If it is a knock from the crank bearings you don't want to drive it if you want to repair the motor. The sooner you stop running it the less damage will be on the crank.
Old 05-21-2010, 01:06 PM   #9
kadinz
the transmission is slipping sometimes, like it has completely just like fell out of gear, went into neutral! idk what this is..
Old 05-21-2010, 01:41 PM   #10
kadinz
