-   -   spark plugs (http://www.toyota-supra.info/forums/mkiii-supra/16804-spark-plugs.html)
supraking74 05-06-2010 01:40 PM
spark plugs
what is the best spark plug to run in my 7mgte? ive heard the E3's are the best, then i hear that there is a better plug... one that runs cooler than stock... what one do i get???
TripleC 05-06-2010 02:28 PM
NGK plugs I can t remeber the specific kind but i would say do a search on this and you wil find gobs of info. I even listed some in the past but i just cant remember the model number 6444 or something. they are a cold plug and i set mine on my 1j to .028 gap
supraking74 05-06-2010 02:30 PM
is that an iridium plug?
TripleC 05-06-2010 02:31 PM
i am Not sure I think it is nothing special (copper maybe) it just stays in the correct heat range to maximize output.
btwilson86 05-06-2010 05:20 PM
In the TSRM it says which plugs to use, all I can remember off the top of my head is 7MGTE's use a double platinum NGK plug with a heat range of 6....
Straight from the TSRM:
7MGTE- NGK BCPR6EP-N8
7MGE- NGK BCPR5EP11
cre 05-07-2010 02:39 AM
Don't run cooler plugs unless you really need cooler plugs... they'll just foul. There's no additional power to be made from just running a cooler plug for the hell of it.
As for the plugs, I don't care for the "boutique" bull $h!t... just stick with NGK copper or platinum plugs.
907mge 05-07-2010 02:51 AM
Any problem with running NGK iridium s since that what i'm using now? My 2zzge uses them but it is a higher compression motor.
cre 05-07-2010 03:21 AM
I ran those the entire time my car was N/A with no problems at all. I just don't think they're really any longer lived than platinums and their actually less conductive.
The whole copper vs platinum vs iridium thing is more a matter of laziness than anything. In the end none costs any less than the other, it's more to do with the frequency of replacement.
supraflymkiii 05-07-2010 04:09 AM
the e3 plugs suck ass. they foul out really quick. my cousin threw them in his wrx with 3" turbo back exhaust intake and stage 2 tune and they fouled out within like 3000 miles
kamikazemkiii 05-08-2010 01:28 AM
Running colder heat ranges on stock hp levels is no good, i run bk7re's i believe thats one step colder than stock but im making more hp.
I head bad things about e3's
btwilson86 05-08-2010 03:34 AM
That is correct. NGK plugs, unlike most others, use lower numbers to represent hotter plugs (ie 1=HOT, 7=COLD)
TripleC 05-10-2010 01:19 PM
Yep the Bk7re's are the plugs i am currently running
