Old 05-04-2010, 01:54 AM   #1
BlueTuner
BlueTuner is on a distinguished road
Default AHHHH so many error codes
Im getting codes 12,14,25,26,34.
Ya alot of codes
heres my thoughts
12- my starter
14- i dont konw
25 and 26- im running lean and rich? thats not good. Help
and 34- No clue.
Mods include a apexi intake, boost controller and turbo timer, fuel regulator and Bosch fuel pump. Really need help because im selling it.
BlueTuner is offline   Reply With Quote
Old 05-04-2010, 02:17 AM   #2
14's the ignition system: Igniter, coil or ECU. It is possible to set this code by pop/push starting the car; Especially if it was already running (ie, the car dies while coasting and you dump the clutch to start it up again).
34 is abnormal turbo pressure... basically your airflow that being reported is WAY off... The lean and rich codes support the likely diagnosis of a crap tune and too much boost to safely operate.
Old 05-04-2010, 02:23 AM   #3
BlueTuner
So how do i fix these problems. Because right now the car wont turn on. I dont get the rrrrr sound of the starter turning.
Ahhhh!!!!! dcrusupra MKIII Supra 1 11-06-2005 02:48 PM
