Old 04-28-2010, 05:42 PM   #1
jason7504
jason7504 is on a distinguished road
Default engine whines to 5000rpm before shifting?
sometimes my engine rev's to like 5000rpm before it shifts,i think for the 1-2 shift or 2-3 shift. anybody know what could be causing this?
jason7504 is offline   Reply With Quote
Old 04-28-2010, 05:51 PM   #2
Supra_Freak_7m
Supra_Freak_7m's Avatar
Supra_Freak_7m is on a distinguished road
Does it rev in between gears with or does it just rev that high in first and then shifts into second?
1987 Toyota Supra 7MGTE AUTO
1987 Toyota Supra 7MGE MANUAL
1990 Toyota Supra 7MGTE AUTO-> MANUAL
Supra_Freak_7m is offline   Reply With Quote
Old 04-28-2010, 05:58 PM   #3
jason7504
i think both
Old 04-28-2010, 06:03 PM   #4
Supra_Freak_7m
Well the shift points are at about 5000 for full throttle, even higher in power mode, but if it is hanging up between gears.
1. Check your fluid
2. Check and adjust your TPS ( Tranny uses input from tps to determine load)
3. Check/Adjust your kickdown cable
4. You could possibly have bad shift solenoid, the tsrm has a troubleshooting section for determing which/if a solenoid is bad. ( there are 2 )
Also try shiting through the gears yourself and see if it still hangs up between shifts
5. If all checks out, consider having your fluid/filter changed
Old 04-28-2010, 08:47 PM   #5
Had the same problem on a 87 N/A auto and that was what fixed it for me
Putting JDM engine in!!! :D dannydavi MKIII Supra 24 11-02-2009 06:30 AM
