Old 04-21-2010, 04:26 PM   #1
brucelee1031
brucelee1031 is on a distinguished road
Default 87 7mgte
just picked up an 87 7MGTE. i heard that one of the niggest flaws of the mkiii supra is the head gasket. my car only has 75000 miles. do any of you suggest changing the head gasket, or it it fine for the time being?
brucelee1031 is offline   Reply With Quote
Old 04-21-2010, 05:40 PM   #2
nfa_automotive
nfa_automotive's Avatar
nfa_automotive is on a distinguished road
Well if you bought JUST the engine and are planning on putting into another car. While you have it out, I'd change the head gasket, timing belt, tensioner, and water pump. Plus any other cheap fix that is easier to do when the motor is out of the car.
It's all stuff I'd do anyway. Cause if you have no records, you don't know how old anything is.
One thing I check and replace when I build a motor is the damned coolent hoses on the back of the head. I had two blow on the same car. Cheap fix and sucks when they blow doing 70 down the road.
1987 Supra Turbo Targa Blue 5spd 175K, 3" Exhaust from Turbo back, Lowered 1.5", 89 Steering Wheel and Climate Control, JDM Power Folding Mirrors, HKS Fan Controller, Greddy Turbo Timer, HKS EVCIII Boost Controller, Boost Gauge, Deleted Boost Gauge in Cluster for Volt, MKIV Non-Turbo wheels
1987 Supra N/A Coupe Blue Auto - Parts Car
1987 Supra Turbo Coupe Black 5spd - Bought with a spun bearing - RIP
1987 VW Jetta GTI Auto 89k
nfa_automotive is offline   Reply With Quote
Old 04-21-2010, 11:12 PM   #3
brucelee1031
i bought the whole car not just the engine. is the gasket fine going several thousand miles more?
Old 04-21-2010, 11:32 PM   #4
nfa_automotive
Yeah you should be fine. As long as you're not over heating or blowing coolant out the overflow tank.
Just do a good check over. Hoses, Spark Plugs, Wires, Filters etc.... Check all the vacuum hoses for leaks. Anything rubber check to see if it's about to or has already cracked. Hard rubber hoses replace them.
Old 04-21-2010, 11:36 PM   #5
brucelee1031
i just took it in for a tune up last week so hoses and all have been replaced. thanks for the advice
Twin turbo on 7mgte? supraman121 MKIII Supra 7 08-24-2007 02:12 PM
7mgte front clip supraman121 MKIII Supra 4 05-31-2007 01:27 PM
