Old 04-20-2010, 02:52 AM   #1
907mge
907mge's Avatar
Default Master Cylinder Leak
I noticed brake fluid seeping out between the brake booster and the master cylinder. I was wondering if it a simple fix of replacing a gasket or do I need a new master cylinder? And also why are master cylinders without ABS so much more common that ones with it.
Old 04-20-2010, 03:03 AM   #2
i think abs is laim anyways...
http://www.cygnusx1.net/Supra/Librar...Section=BR&P=9
Yes there is!
maby a commen part, if not some rtv, or other tube gasket
first check to see if the bolts are loose,
dont think u need a new master until one of the rubber pieces inside brakes and i think u might be able to rebuild it, but a new one is no more than 50 dollers
How hard is the clutch master cylinder to replace? the#1 MKII Supra 2 05-27-2016 04:32 AM
Clutch Master Cylinder question. 1989 Supra. PFlanagan MKIII Supra 4 08-07-2008 08:20 PM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
