Old 04-12-2010, 11:32 PM   #1
chrismel
chrismel is on a distinguished road
Default ? on diff form87 t a
i have a n/a 87 supra 5 speed and need a diff,I can get a diff from 87 automatic turbo, will that work?
thank Chris
chrismel is offline   Reply With Quote
Old 04-13-2010, 12:08 AM   #2
87mk111
87mk111's Avatar
Should work just fine, Looking to upgrade to a LSD diff?
Old 04-13-2010, 01:46 AM   #3
chrismel
thanks for the info, i just need to replace the stock diff, my bearing and seals are bad and all new stuff is to much money.
Old 04-13-2010, 01:51 AM   #4
907mge
907mge's Avatar
If you look around you can find a LSD
This may help
http://cjsupra.kendra.com/graphics/M...e/diffdeco.jpg
Old 04-13-2010, 03:21 PM   #5
the gear ratio is quite different.
Old 04-13-2010, 10:50 PM   #6
chrismel
the gear ra.. my be different but will it bolt up,i just need a replacement,what will be the pro/cons of the switch?
Old 04-14-2010, 12:56 AM   #7
Odometer will be significantly off, same for the speedo (and no, no replacement drive gear for the send is available for the W58 as far as I can find). You'll also lose acceleration, but your highway mileage will increase. Depending on how you drive in the city you mileage may suffer.
I ran a 3.91 from a pre89 GTE on my N/A for a while. I liked it for a commuter but I could definitely tell the difference when I opened it up.
If you're just trying to keep it moving, go for it, but it's not a performance upgrade.... If you just want a LSD then find a 4.30 LSD from a N/A.
Non Turbo diff vs Turbo diff. abhattan MKIII Supra 0 04-18-2007 11:20 PM
Help..Diff Cont Indicator On (off) / No Speedo Malachiman MKIV Supra 8 03-13-2007 09:25 PM
Rear Diff? supraman121 MKIII Supra 4 11-19-2006 06:47 AM
open end diff. sucks!! 88Supraboy MKIII Supra 2 11-09-2005 08:16 AM
