Old 04-09-2010, 01:18 AM   #1
2genfun
2genfun is on a distinguished road
Default 2jz install...
ok im set on 2jz installation in my mk3...im gonna put some goodies in it once i get it of course. So...the question is will the exhaust fit? and how do i need to wire in the harness? and will a 5spd work with it? im not to keen on all the letters and numbers for the trannys...r154? Is that auto im guessing? i'd really like a 5 spd cuz the 6 is a hassel i hear. All comments help! thanks
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
2genfun is offline   Reply With Quote
Old 04-09-2010, 03:52 AM   #2
I would go to supramainia forum. they have a whole sub forum devoted to swaps.. tons of info there
good luck.
Old 04-09-2010, 04:24 AM   #3
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
Also check around on supraforums as well and 1jz kings, they've got some good information on the swap.
quick note, the r-154 is the MKIII turbo 5 speed, the w58 is the non-turbo 5 speed for the MKIII and MKIV. the A340 is the auto tranny i believe.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
Old 06-04-2010, 10:48 AM   #4
41richie
41richie is on a distinguished road
check out www.phoenixtuning.com
41richie is offline   Reply With Quote
anyone install aftermarket stereo? dannydavi Car Audio and Alarms 10 03-17-2012 10:41 PM
Boost gauge install location Durandal MKIV Supra 1 07-26-2009 11:55 AM
water temp gauge install sundevil1 MKIII Supra 3 12-09-2008 04:38 PM
How to install a oil temp controller ? Supra-Iceman Non-Generation Specific Questions 4 01-30-2007 11:18 PM
hks TT install mizuboi MKIII Supra 11 11-17-2006 03:04 AM
