Old 04-07-2010, 03:45 PM   #1
seth959ci
seth959ci is on a distinguished road
Default 92 7mge idle issues
hi, my supra N/A has issues when idling, sometimes it will idle at 1500rpms and sometimes it will struggle to idle at all.. any ideas? the car runs fine while driving
seth959ci is offline   Reply With Quote
Old 04-07-2010, 08:03 PM   #2
seth959ci
any help guys?
Old 04-07-2010, 08:12 PM   #3
might be a vacuum leak. do a search for the symptoms your having and see what that turns up.
check for codes first.
Old 04-07-2010, 09:36 PM   #4
seth959ci
thanks gonna hopefully run codes on it soon, gotta find time for that though I just dont want it to be the Idle air control valve... those things get pricey
Old 04-08-2010, 01:37 AM   #5
907mge
907mge's Avatar
the ISC(idle control) is easy to check
it should make a few clicks right after shuting the engine down at least thats what the toyota manual says
Old 04-08-2010, 02:49 PM   #6
tStart with checking for error codes (see the FAQS), then check the TPS calibration and then the ISCV. That's the order I'd approach it in.
Old 04-08-2010, 04:17 PM   #7
MA70-3.0GT
MA70-3.0GT's Avatar
Can't put it much better than that, and if the ISCV does turn out to be the prob. it's not always doom & gloom. A fair proportion of the time they're just glued up with old oil & crud & a good clean with brake cleaner spray can sort 'em... For my money though if it's intermittent I'd suspect the TPS (bet the EML comes on when it won't idle, if it works! next time it won't idle do the diag. check before touching the throttle again & see if you get a code 51...)
Last edited by MA70-3.0GT; 04-08-2010 at 04:23 PM. Reason: remembered what code is what!!!
Old 04-10-2010, 01:57 AM   #8
seth959ci
well ran the codes.. codes 41 and 51... TPS and air conditioner switch lol.. getting the TPS tomorrow cant find anything in my book about the switch though.. but better to fix mechanical issues first
Old 04-10-2010, 02:08 AM   #9
http://www.cygnusx1.net/Supra/Librar...ction=FI&P=100
Old 04-10-2010, 12:55 PM   #10
MA70-3.0GT
MA70-3.0GT's Avatar
DON'T GO & BUY a TPS!!!! All the code 51 means 9 times out of 10 is you need to calibrate it as per cre's link! (click next page for info on the actual calibration process after ensuring your vacuum pipes are as they should be...) I should have been more clear really & said I'd suspect the TPS calibration rather than saying just the TPS, sorry that's what rushing to finish a post before dinner does to you!
idle problems 88 supra turbo MKIII Supra 14 03-13-2010 03:43 AM
4runner 7MGE swap idle problem grabber MKIII Supra 3 06-26-2008 11:45 PM
Lumpy idle 7MGE spadam1983 MKIII Supra 0 05-02-2008 06:50 PM
