Old 04-06-2010, 07:12 PM   #1
StonecoreTx
StonecoreTx is on a distinguished road
Default todays "name that noise"
I've noticed a noise coming from my rear end and havn't had the time to attack it yet but open to any ideas.
Sounds like a single clunk everytime the wheel makes a full rotation but goes away under load. sound stops when accelerating.
It happens only when coasting to a stop, low speed turns, slow reverse.
my diff is fine and full of a bluish performance gear oil and boots are good.
someone said it might be a bad caliper or wheel bearing but maybe not becuase it goes away under load...
maybe a dry driveshaft?
86.5 mk3 supra 7mgte r154
StonecoreTx is offline   Reply With Quote
Old 04-16-2010, 09:06 PM   #2
suprabahamut
Could be a bad strut or shock. Look under to see if one is leaking.
Old 04-17-2010, 03:48 AM   #3
Krem
I got something similar to this... not exact... but it seems to be most evident when I'm turning or actually accelerating... However, mine is a rattle caused by the latch on the side of the hatch not seating right with the latch on the inner lining of the trunk. I just haven't been able to find a new latch for the inner lining of my trunk short of getting it from toyota for $80.
Old 04-25-2010, 08:43 PM   #4
StonecoreTx
Jacked the rear end up to see if anything is loose, come to find out i'm missing a diff mounting bolt/washer near the driveshaft. anyone know what size this would be?
http://www.cygnusx1.net/Supra/Librar...aspx?S=RA&P=23
tq is 1,690 (122,166)
