Old 03-31-2010, 05:02 AM   #1
pacman7mgte
pacman7mgte is on a distinguished road
Unhappy overboosting
i have a 91 turbo supra (automatic transmission ),i need some advice.. my car is drivable, but when i hit the gas to pass someone or just because, the boost needle goes up to 15 psi (more less) on my aftermarket meter and the stock goes all the way to the top,, after that is total downhill cause the check engine light comes on (for a second or so) and i start to worry cause i dont want another bhg,, i think im experiencing fuel cut?.. what could be the reason for that boost pressure? i dont have any mods, only hks mushroom filter and hks ssqv bov and my exhaust has no catz just a muffler with a 4 inch tip. I want stock boost not this crazy thing,, could it be that my boost pressure sensor has gone bad? or my wastegate actuator? or the timing is off??... when idling it doesnt shake or knock nothing like that, the idle is perfect it sounds clean and deep... ANY ADVICE?
pacman7mgte is offline   Reply With Quote
Old 03-31-2010, 07:59 PM   #2
you should be hitting fuel cut earlier, IMO. You are overboosting, unlikely that two different gauges are both wrong and the ECU doesn't monitor boost pressure. check the error codes yet? I bet theres one for abnormal boost pressure.
Check the waste gate, actuator and vacuum hoses.
Old 03-31-2010, 08:25 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Without a doubt, no cats and shimmed waste-gate will produce 15 psi resulting in fuel cut-out.
Old 03-31-2010, 09:05 PM   #4
pacman7mgte
Who said anything about shimmed wastegate?
Old 03-31-2010, 09:59 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
No one, but thought I'll mention it as mine did the same when I first bought my first Turbo Supra, just in case yours is shimmed. I ended up fitting the second cat back on.
Tags
overboosting
