Old 03-24-2010, 03:38 PM   #11
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
Yea sounds like he's low on transmission fluid.
cvbikeguy is offline   Reply With Quote
Old 03-24-2010, 06:17 PM   #12
chinesedawn
chinesedawn is on a distinguished road
I got a 1987 supra 7mge + 5speed MT Not auto transmission so fluid won't affect power transmit
chinesedawn is offline   Reply With Quote
Old 03-25-2010, 02:06 AM   #13
2genfun
2genfun is on a distinguished road
check the cat convertor...
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
2genfun is offline   Reply With Quote
Old 03-25-2010, 02:15 AM   #14
Cameroonski
Cameroonski is on a distinguished road
I had a similar-ish problem. I re-zeroed out my timing and reset all the timing stuff. Cams to TDC and pully to zero. Make sure it is EXACTLY right, mine was only off by a notch and it gave me almost now power. Good Luck!
Cameroonski is offline   Reply With Quote
Old 03-25-2010, 04:10 AM   #15
chinesedawn
Thanks , I will do it tommorw, I wish get some power!
Old 03-25-2010, 07:03 AM   #16
chinesedawn
Red face the 3 holes on cam sprockets
there is a pin for the cam sprocket and camshaft to line up, the pin should go to the middle hole of the cam sprocket right?
Old 03-25-2010, 01:16 PM   #17
Yes, you are correct.
Aftermarket shifters for R154 trans MKIII? Boombastic Exterior , Interior, and Detailing 4 08-11-2010 04:28 PM
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
getaway in stockholm... (i think thats how you spell it) kelogg Road Racing & Autocross 3 06-03-2008 10:53 PM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
