Old 03-08-2010, 04:36 PM   #1
john_lauj
john_lauj is on a distinguished road
Default my 89 supra turbo choke at 3800 rpm
yea my 89 supra turbo chokes and gets fuel cut. when i bought the car the guy said he was boost about 12 psi. so wat i did was i got a ls400. it stop the fuel cut but still the car was hesitated to go past 4000 rpm. so my next guest was to put a 3 inch all the way. i did it but now i get the fuel cut again and still choke about 3800rpm.
ANY HELP GUYS
john_lauj is offline   Reply With Quote
Old 03-08-2010, 04:48 PM   #2
TripleC
TripleC's Avatar
Did you check the gap on your plugs. I had a hick-up at around 4500 to 5000 and thats what my issue was.
ANY HELP GUYS
1JZGTE ,R154, Hallman Boost Controller, HKS bov, HKS Mushroom top Air Filter, HKS Front Mount Intercooler, Greedy Turbo Timer, PLX300 AFC, Custom Divorced Y-pipe, Custom Intercooler Pipeing, RS-R Concept Exhaust, Optima Red Top Battery, Strut bar Brembo Rotors, A1 Traction arms, Megan Coilovers, Stern ST 2 wheels rear 265x30 r19 - front 245x35 r19, New Front Lip, 18 x 8 and 18 x 9 MRR HR2 with whatever for Drift treads
2 additional C12A turbo's(Extra)
Old 03-08-2010, 04:49 PM   #3
Cyto
Cyto's Avatar
Cyto is on a distinguished road
Mines doing the exact same thing.... Except at like 4200. I just changed the fuel filter, and found out my wastegate actuator wasn't connected to the wastegate flange. So I hooked it back up, and now it's doing that.
It's crazy. If you get any break throughs let me know lol I shall do the same.
Proud owner of a 1988 Toyota Supra Turbo, 105k Miles, and great condition.
I might have to sell it to help pay for school so here's the link.
http://www.toyota-supra.info/forums/...html#post72357
Cyto is offline   Reply With Quote
Old 03-08-2010, 04:54 PM   #4
john_lauj
Also my boost is no accurate. 1 gear ill be boosting 4psi, 2 ill be boosting anywhere from 4-6, and same with the rest of the gear. if i keep pushing it, ill get fuel cut about 4500-5000 rpm.. oh yea i also recently replace my spark plugs too.
Old 03-08-2010, 05:00 PM   #5
TripleC
TripleC's Avatar
What was the gap you set them for ? and did you look to see if your coils had any cracks (people have had this hapen before) on them.
Do you have a FMIC?
Old 03-08-2010, 05:08 PM   #6
john_lauj
it came pre gap already. im also a new member to the mk3 family so like fmic or afm all that is new to me so can u please b more specific with me. i will like to learn them too.
Old 03-08-2010, 05:12 PM   #7
TripleC
TripleC's Avatar
The gap is usually preset but can be out of range from the factory. i would pull them out and get one of those 1$ gauges from Autozone and make sure they were all at the same setting. Secondly a Front Mount Inter Cooler or FMIC would have cylicone hoses that could have a leek.
Air Fuel Meter = AFM
Old 03-08-2010, 06:18 PM   #8
john_lauj
if i slowly gas it will go with no choke. only when the turbo spool hard is when i get the choke. someone has told me that its my speed box unit but i doubt it. i dont want that to be the problem.
Old 03-08-2010, 06:20 PM   #9
TripleC
TripleC's Avatar
Dude i had this same issue i could go easy and excelerate so there was no missfire but if i punched it it would miss around 4-5. Re-gap our plugs to around .028. do this then let us know what ahppens
Old 03-09-2010, 01:28 AM   #10
ANY HELP GUYS
What size injectors are you running? You say you added a Lex AFM, but you don't say anything about upgrading the injectors along with it... which you need to.
Information about non turbo Supra Jimbo_2JZ Non-Generation Specific Questions 3 02-20-2009 10:13 PM
1988 Toyota Supra Turbo runs very rich need help PhillyKorean Non-Generation Specific Questions 0 10-25-2008 03:28 PM
HorsepowerFreaks Turbo M3 vs Single Turbo Supra ChrisB Non-Generation Specific Questions 0 01-01-2007 04:56 PM
