Old 11-15-2005, 06:19 AM   #11
1988gte
stock guage
Old 11-15-2005, 09:51 PM   #12
Bullz_EyE
Bullz_EyE's Avatar
It's possible that your stock gauge is inaccurate. It's also possible it could be a close representation of your actual boost? What breathing mods have you done?
As for the topic, no one else wants to chime in here?
Old 11-15-2005, 10:22 PM   #13
joel w
joel w's Avatar
personally i would recomend an aftermarket gauge, incase you ever blow a waistgate vac/boost reference line like i did.. I looked down and i was at about 20 psi... and stock gauge pegs at 8 so youd never know it if it ever happened to you.
and i like to adjust boost inside cab with moddified manual air regulator, but thats just how i roll... bleeder valves work pretty good too and way cheap...so will the washers just dont over do it...
Old 11-16-2005, 03:09 AM   #14
ryemann32
ryemann32's Avatar
ryemann32 is on a distinguished road
Default i shimmed mine today
wow what a diffrence i thought i would shimm this turbo while i wait for my new stuff to get here,what a blast on my way home from work, only takes about 20 minutes to do to,i only put in 3 washers but they looked alittle bigger than normal so i only put in the 3, my stock gauge would bary when i laid into it would let loose even easier thanx for the thread was lots of fun
ryemann32 is offline   Reply With Quote
Old 11-16-2005, 03:34 AM   #15
Luin Haden
Luin Haden's Avatar
Luin Haden is on a distinguished road
The factory boost is 6.7
-Luin Haden
Sparta, MO
Owner of a 1990 Targa Top 5 speed Turbo Supra
It isnt pretty now, but just wait.
Luin Haden is offline   Reply With Quote
Old 11-16-2005, 08:47 PM   #16
1988gte
Bullz_EyE everything is stock but the shims. Just had to try it out. What is a good aftermarket?
Old 11-16-2005, 08:51 PM   #17
1988gte
I think that joel williams way sounds good and safe. I will take shims out on my next day off. But its fun!!
Old 11-16-2005, 09:12 PM   #18
joel w
joel w's Avatar
i wouldnt go over 10 psi on stock ct-26, i killed 2 stock ct's doing that..
and i would not play with a boost valve untill you upgrade your boost gauge 4 sure.. nice piks on your other post.. gj and happy boosting.
Old 11-17-2005, 06:04 PM   #19
Reeves
Reeves is on a distinguished road
Would I be safe doing this with 3 or 4 washers on a totally stock supra? This is just too good to resist, but I don't want to mess anything up.
Also what is the average price for a decent gauge? Im looking online and they seem pretty expensive (for me).
Reeves is offline   Reply With Quote
Old 11-18-2005, 12:34 AM   #20
1988gte
i have four shims and its a new car no problems for 600 miles or three tanks worth of fun
External Wastegate! teedoff00 MKIII Supra 1 04-11-2007 03:49 AM
Wastegate? drmmr15 MKIII Supra 19 01-16-2007 07:07 PM
Shimming the Wastegate Supra2NR MKIII Supra 26 09-20-2006 12:15 AM
