Old 02-07-2010, 08:15 AM   #1
Cyto
Cyto's Avatar
Cyto is on a distinguished road
Default Cat?
Does a cat converter have anything to do with performance on this car?
Proud owner of a 1988 Toyota Supra Turbo, 105k Miles, and great condition.
I might have to sell it to help pay for school so here's the link.
http://www.toyota-supra.info/forums/...html#post72357
Cyto is offline   Reply With Quote
Old 02-07-2010, 02:31 PM   #2
brad88supra
brad88supra's Avatar
brad88supra is on a distinguished road
a catylitic converter halps to make your exhaust cleaner, your exhaust will flow better without, rendering better performance
1988 N/A Supra, 5 speed, Targa top, Tems
brad88supra is offline   Reply With Quote
Old 02-07-2010, 04:31 PM   #3
mirage83
If it's blocked-up it will cause a definate exhaust flow restriction which you don't want. If you think you have a problem, I'd recommend one of the Magnaflow hi-performance cats. They do what a cat is supposed to do with low flow restriction, and help mellow out the sound of your car.
Old 02-09-2010, 08:06 PM   #4
megawatts
megawatts is on a distinguished road
Question Cat Light comes every so often
Engine is "motor boating" on cold wet days, after start up. Some times the "CAT" light comes on.
Is this justa worn out Lamda / O2 sensor? Or is the CVat in need of replacement?
megawatts is offline   Reply With Quote
Old 02-10-2010, 01:14 AM   #5
kamikazemkiii
kamikazemkiii is on a distinguished road
Do you check codes? your cat may be clogged, i say that because supra's run pretty rich in stock form
kamikazemkiii is offline   Reply With Quote
Old 02-10-2010, 03:56 AM   #6
"CAT" light? That's new... Mind posting a picture of this light?
Old 02-10-2010, 05:29 PM   #7
Green7mgte
Supra Forum Moderator
i was gonna say whats a cat light. but then i decided against be fearing there might be one! hmm were did i put that link for dash board lights.
http://www.toyotanation.com/forum/sh....php?t=262353&
i think i seen a better One pic example before.. maybe not tho.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 02-11-2010, 01:52 AM   #8
supradaddy0803
supradaddy0803's Avatar
Hmmmm CAT light let me check....... low coolant light, check engine, taillight blown, ABS, Blinkers, High Beam, TEMS. Hmmmmm nope no CAT light there. Coolant light kinda looks like a CAT but only just kinda.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
