Old 08-19-2005, 07:52 PM   #1
dcrusupra
dcrusupra's Avatar
As of right now, my 87 idles at about 600rpm. It should be 800. My idle rpm varies from about 550-1000. Is there a way i can lock it in to 800? Engine is stock except for a new intake.
New Rebuild
My CarDomain
Old 08-20-2005, 10:29 AM   #2
ddmcse
ddmcse's Avatar
your idle speed control valve could be shot
is this a turbo or N/A?
i am assuming it's a n/a because of the idle rpm of 800 you quoted
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 08-20-2005, 04:55 PM   #3
dcrusupra
dcrusupra's Avatar
Yea its an N/A. It only does this for the first startup of the day. After I drive it around for a little, it stays around 800-900rpm.
New Rebuild
My CarDomain
Old 08-20-2005, 11:05 PM   #4
Poodles
Poodles is on a distinguished road
I dunno if it will help an N/A, but I was having problems on my turbo model and it was a vacuum leak, changed the vacuum lines and it idles prefect now.
Poodles is offline   Reply With Quote
Old 08-23-2005, 04:38 AM   #5
joel w
joel w's Avatar
check the contiuity of the throttle position sensor, should have cont when fully closed. its the bottom 2 of the 4 terminals to check. if no cont then loosen the screws and adjust it to where there is continuity. i dont know why but i have had to do this twice to my car. impossable to time it unless the tps is closed. and it idles rough and will die sometimes if i let off gas to fast. try vac lines first of course.
Old 08-23-2005, 01:48 PM   #6
Troyota
Troyota is on a distinguished road
It could be the idle up sensor, that races the engine when it's cold...mine did this, it would also stall when stopped at traffic lights with the A/C running because the idle wouldn't increase w/ it on.
1987 N/A MA70 Supra <--1JZ swap in progress
1986 AE86 GT-S Hatchback
2002 DC5 RSX Type S
Troyota is offline   Reply With Quote
Old 08-23-2005, 07:19 PM   #7
SupraDave
SupraDave is on a distinguished road
[QUOTE]check the contiuity of the throttle position sensor, should have cont when fully closed. its the bottom 2 of the 4 terminals to check. if no cont then loosen the screws and adjust it to where there is continuity. i dont know why but i have had to do this twice to my car. impossable to time it unless the tps is closed. and it idles rough and will die sometimes if i let off gas to fast. try vac lines first of course.
Be careful when checking the TPS. Look to see if the sensor connector faces the passenger side or drivers side. If your car is like my 86.5 N/A then the connector is on the driver side and the check terminals are the top two.
You can see what I'm talking about by viewing the attached link.
http://www.supra.co.nz/87tsrm/EFI/efi102.htm
SupraDave is offline   Reply With Quote
Old 08-24-2005, 01:12 AM   #8
joel w
joel w's Avatar
good call, mine faces the passenger side. i think its IDL and E2 terminals
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
Rough Idle????? ZauggIt1 MKIII Supra 2 11-11-2006 08:50 PM
rough idle problem vladkalika MKIII Supra 5 11-28-2005 10:07 PM
Rough idle / stalls on cold start? mk3-drft MKIII Supra 3 04-08-2005 03:34 AM
Rough idle 1989 turbo auto WHITETURBO Non-Generation Specific Questions 1 01-21-2005 08:35 AM
