Old 12-17-2009, 02:21 PM   #1
2Fast2Furious
2Fast2Furious is on a distinguished road
Default Stock MKIII
with 225/50/16" rims and tyres
ID:	2672   Click image for larger version
ID:	2673   Click image for larger version
ID:	2674   Click image for larger version
ID:	2675   Click image for larger version
2Fast2Furious is offline   Reply With Quote
Old 12-17-2009, 02:22 PM   #2
2Fast2Furious
and more pictures of my beauty
ID:	2677   Click image for larger version
ID:	2678   Click image for larger version
ID:	2679   Click image for larger version
Old 12-17-2009, 02:26 PM   #3
2Fast2Furious
Default New 19's fitted
new 235/35/19" rims & low profiles fitted (these wheels are et35)
ID:	2681   Click image for larger version
ID:	2682   Click image for larger version
ID:	2683   Click image for larger version
ID:	2684   Click image for larger version
Old 12-17-2009, 02:29 PM   #4
2Fast2Furious
what a difference a nice set of sharp alloys can make
ID:	2686   Click image for larger version
ID:	2687   Click image for larger version
ID:	2688   Click image for larger version
ID:	2691   Click image for larger version
Old 12-17-2009, 02:31 PM   #5
2Fast2Furious
Big Brake upgrade is now imminent, with calipers painted bright yellow
ID:	2692   Click image for larger version
ID:	2693   Click image for larger version
ID:	2694   Click image for larger version
Old 12-17-2009, 05:04 PM   #6
2Fast2Furious
I have my eye on a Gran Turismo Big Brake kit with Brembo rotors.
Pretty expensive, like will I have to get a front and a rear kit, assuming I want both?
Should I opt for drilled (preferably cross drilled) over slotted or both?
Sequential pistons. How many does stock brakes have - is it 1? No real need to go up to 8 for a street car because it will decrease overall driving performance, am I right?
This car is not for racing, I just like to have the best, assuming this should I go with drilled then and maybe 4 pistons?
Old 12-18-2009, 03:36 AM   #7
2Fast2Furious
I want my calipers painted, and because I am styling the outside first before I even start on performance mods and ICE setup I thought heck it I'll get it done now cuz it'll look wicked, why bother painting calipers your not going to use anyway. I was going to be upgrading my braking system and suspension down the line I have just changed the order I am doing it.
Originally Posted by krem
I think our cars are only 1 cylinder for brakes... and if you're not racing, I don't really see a point to having a different cylinder for each brake.. Also I remember reading (from many references) that our rotors (especially the fronts) like to warp. Getting drilled rotors, though it looks cool, would probably reduce the integrity of the brake rotors. I understand if any rotor option other than flat rotor is used on the mkIII, it should be slotted and not drilled so you can still have some integrity in the rotors.
To each his own.. but my mkIII won't see any high perf. brake upgrades like that till she's strong enough to actually need them... till then, I, myself, will be saving the money for fixing whatever problematic issue pops up next...
Its not a different cyclinder for each of the four brakes, the brakes on each wheel are all the same, its the pistons on the same brake and each brake that are smaller or larger.
Also if I was getting a Big Brake upgrade that includes rotors and therefore the stock rotors wouldn't be in the equation, the rotors in this package are Brembo rotors the best on the market. If stock rotors warp isn't it clearly a good thing to change the braking system. Getting drilled rotors may reduce the integrity of the overall rotor compared to a none drilled rotor but the dissipation of heat in a drilled rotor is much more beneficial in my opinion when compared to a non-drilled rotor.
Originally Posted by bustedknuckles
Drilled and slotted rotors look cool, but spending a ton of money on brakes for better performance is a lost cause on a stock set-up.
Ye I see your points, think brakes when I have my HP up. I'm Irish, I do things arsed ways, lol
NO THUMBS UP ON THE WHEELS THEN OR DO YOU ALL LIKE YELLOW SUPRAS, lol
Old 12-18-2009, 05:54 AM   #8
since were talking stylized calipers. purchase a set of these
http://cgi.ebay.com/ebaymotors/ws/eB...3D10%26ps%3D63
thank god i found them. otherwise i was gonna have to fabricate a stencil of my own.
Old 12-18-2009, 08:23 AM   #9
2Fast2Furious
sweet
thanks for the link
hadn't even though of that but very good idea, its those small touchs that make the difference
Old 04-13-2010, 04:58 AM   #10
cvbikeguy
cvbikeguy's Avatar
i know this is old but.....
YOU ARE MY HERO!!!!!!!!!
question about the stock BOV on a MKIII Turbo TehEl1te Non-Generation Specific Questions 3 08-23-2009 10:20 PM
1993 BMW CI vs stock MKIII supra west_side_supra MKIII Supra 2 04-15-2007 09:24 PM
93 BMW 328ci versus a stock MKIII turbo supra west_side_supra Road Racing & Autocross 1 04-14-2007 01:20 PM
