Old 12-08-2009, 07:53 PM   #1
916MKIIIx2
Default Megan Racing Track Series Coilover settings?!?!?
Alright, so I ordered a set of these megan coilovers for $500 through a friend. Was hoping I could get some suggestions for corner weights and ride height settings for smoooooth sailing.
Here is the coilover model number for more information on this set: MR-CDK-TS86TS
Old 03-10-2011, 08:20 PM   #2
916MKIIIx2
Oh yeah, these were shitty... ended up sending them back and getting BC's.
Old 03-11-2011, 06:07 PM   #3
Travis89Turbo
Travis89Turbo's Avatar
Good to kno. Thanks for the follow up! How much were the BC's?
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 03-14-2011, 08:11 PM   #4
916MKIIIx2
BC's after tax were about 1100, installed them myself, they come with pre-load options by model also but the pre-loads are fairly conservative. After tuning the spring rates and ride height, the BC's are performing on par with my TEIN SS setup on my 1990 targa supra. I use these for a drift setup so they are pretty much trying to be broken atleast twice a month, had these for about 6 months now and not even the end links are showing wear, good sign for those interested in something that won't break after taking it around the track a few times. Downside of the BC's, too many ranges of adjustability to actually feel like each click is doing something, also very stiff have to turn down to almost two clicks away from max soft to get a ride that doesn't make you want to drive fast everywhere. Also if you do get these make sure they are 2010 production or higher, the pre 2010 BC's were made with lower quality metal's and are not nearly as robust as the improved coilovers. Something that won't be mentioned to you when you buy, so make sure you point it out.
2009 Track Dates and Invitation Feffman Events & Other Announcements 0 08-27-2009 06:07 PM
Megan Racing Coilovers panblackrose MKIII Supra 8 12-23-2008 08:06 PM
Megan Racing Compared to ebay strut bar. The_MuffinMan25 MKIII Supra 5 11-12-2007 09:57 PM
BLITZ Nur Spec Racing Series Cat-Back Exhaust System??? HeadofaHessian MKIII Supra 0 11-10-2005 05:24 AM
