Old 12-04-2009, 02:30 PM   #1
munchie
munchie is on a distinguished road
Default lights stays on
I would like some suggestion from anyone who can help me out with this problem. I install a system in my car and had the light switch off. Next thing you know the corner and projector lights stay on and drain my battery. I would like to get help on what can I do to stop this from happening. I check the fuse box inside the car if I were to take out one of the fuse the projector wouldn't stay on. I check the ground wire for my system it wasn't that either and the ground wire for the cd player too. I hope this help.
munchie is offline   Reply With Quote
Old 12-04-2009, 07:32 PM   #2
dunewarz
dunewarz is on a distinguished road
It's a wiring problem but since they are so complicated without actually being there, there's not much help anyone can give you. Just recheck all your wiring, if you don't know much about wiring take it to a professional.
dunewarz is offline   Reply With Quote
Old 12-04-2009, 07:40 PM   #3
It is possible you connected an incompatible illumination wire from the stereo to the dash harness which is holding the relay high. If you did wire in any illumination wire try disconnecting it and report back.
NO TAIL LIGHTS!!!! quick fix Mk3beast Non-Generation Specific Questions 1 08-24-2009 08:35 AM
LF: Lightbulbs guide lamw001 MKIV Supra 2 09-18-2008 02:23 PM
Brake lights not working! lifesnotfair MKIII Supra 18 05-05-2008 11:40 PM
Dash lights and Side marker lights are not working ebang MKIII Supra 0 04-01-2008 12:35 PM
