Old 12-04-2009, 03:02 AM   #1
BlueTuner
BlueTuner is on a distinguished road
Default spark plug?
I recently just got a 89 Toyota Supra. My question is what spark plugs do i use, not brand put the specifics of the spark plugs used in the car. Also i was watching PowerBlock and they where talking about using special copper o-rings used to make the spark plugs all go in straight to increase hp and fuel efficinty. I cant find it again. If you guys remember what its called please tell me. Also a good brand will be nice, like ngk, auto light, etc.
BlueTuner is offline   Reply With Quote
Old 12-04-2009, 03:31 AM   #2
The factory installed NGK Platinums are a VERY good plug and really are the preferred plug. If you need something less expensive for the time being you can use copper plugs but they have a significantly shorter lifespan. I like NGK's iridium plugs; They cost the most of the three but are long lived and consistent. I generally recommend people stick with NGK's regular platinums for a stock engine.
I do not recommend any other brands unless you specifically measure them. There are two different standards used for spark plugs and the size difference in insulator length can cause problems. Autolite's, for example, use the ISO standard and as such the insulator is around 4 or 5 mm shorter than that on the recommended plug. This can lead to shorts to ground with plug wires that are older or aftermarket plugwires with a looser boot.
NGK's plugs come pre-gapped. Do not try to re gap platinum or iridium spark plugs unless you've got the right tools... they are very easily damaged! Always check the gap though and regap copper plugs if needed. Additionally, there IS a big difference in the specified temperature and gap of GE plugs versus GTE.... make sure you get the right ones.
Spark plug shims or indexes aren't a bad idea but are unlikely to return any significant gains on a stock 7M (GE or GTE). If you feel like taking the time to try it out feel free, it's not going to hurt anything.
Old 12-04-2009, 03:47 AM   #3
I suppose I should add that you don't want to add shims to every plug. If it is possible to install the plugs in the desired orientation with just a *tiny* bit less or more torque then do so.
A note to all of you who read this: ALWAYS torque your spark plugs with a torque wrench!!!!!
Old 12-05-2009, 04:24 PM   #4
Busted Knuckles
Busted Knuckles's Avatar
Not to take away anything cre mentioned, as his advise is really solid as always, but indexing the plugs in the head design that Supra uses is a useless gesture. In Chevy's, Ford's, and other deigns that have the spark plug on the side of the combustion chamber, spark plug indexing can have more of an effect, since an electrode can easily impede the flame front from reaching the rest of the fuel/air charge. On Supra's and other similar designs, the spark plug is dead center of the symmetrical combustion chamber. It has no effect which direction the electrode is pointing.
Old 12-06-2009, 02:53 PM   #5
MA70-3.0GT
MA70-3.0GT's Avatar
I'd never heard of plug indexing until this thread, suppose it's not a bad idea on assymetrical chambers but like knuckles said, not much use on a Supra or similar pent-roof designs.
Just as a side note on torquing spark plugs. I've never torqued a washer type spark plug, simply going with the advice on the box (tapered plugs are a different matter & correct torque can make the difference between getting old plugs out or them snapping).
Generally when re-using an old washer type plug I don't even follow the advice & simply tighten by hand & then nip up with one of the old bendy "T" bar plug wrenches, never had one come loose or leak yet & never had to worry about snapping them come removal time.
I don't know what Toyota's torque reccomendation is, but I'd wager it's way more than is really needed to do the job... Unlike their head torques
Old 12-07-2009, 05:59 AM   #6
There's still a benefit to indexing plugs in engines like ours but, like I already said, you're not going to see it (not unless you're pushing TONS of boost or your plug's gap is too large); it is there though. The airflow coming into the cylinders isn't nice and clean. The valves throw the air out sideways and while the air moving up toward the peak of the head loses a lot of its momentum from the collision there the air moving downward rolls around the top of the piston and tries to move up the other side, The piston's upward momentum presses all the air upward, but there is usually a pressure differential from one side of the cylinder to the other. Unless you've managed to pour the water into the dead center of the glass, it's going to roll up the other side.
I really hope I remembered enough of the specifics about that right... It's been a while since I've read up on that matter. If that doesn't make sense let me know and I'll see if one of my friends (who know a LOT more than me) can explain it more clearly.
13ft lbs
... Not too much... your method works well enough; Try it your way sometime and then hit them with a torque wrench and see how close you are.
Old 12-07-2009, 05:17 PM   #7
TripleC
TripleC's Avatar
I saw the same thing and wanted to see if anyone here had done this befor. It looked to be a fairly realistic concept
Old 12-07-2009, 07:47 PM   #8
As stated my Knuckles and myself, it is highly unlikely that you will notice any difference (perhaps a placebo effect); It won't hurt anything for you to try it out either though. I've never bothered with it on my Supra... just my old Chevy's.
Old 05-09-2010, 11:21 PM   #9
batmmannn
batmmannn's Avatar
Default Spark Plug Wrench?
Spark park Plug wrench socket size? My regular does not fit. Thanks
Spark plug wires Quik Q carfanatic89 MKIII Supra 2 05-22-2008 01:46 PM
Broken spark plug! HELP! supraman121 MKIII Supra 2 10-02-2006 08:40 PM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
spark plug wires kewlcoconut MKIII Supra 2 03-19-2006 07:45 AM
stripped spark plug *c-town* MKIII Supra 3 12-20-2005 03:27 AM
