Old 11-10-2009, 02:42 PM   #1
Default Rad leaks
so my rad leaks like mad...
gona get new upper and lower rad hoses, and replace hose clamps...
my lower hose looks longer than it should be should i make it a more direct path??
Old 11-10-2009, 07:31 PM   #2
What's leaking, the rad or the hoses?
The lower hose it curved the way it is to avoid rubbing in a couple spots... I believe it is more of an issue with GTEs though. If you want to try a more direct hose I believe the hose from MKII Supras is a direct fit; although there's really no benefit to it.
Old 11-12-2009, 05:21 AM   #3
cant tell if it is upper or lower hose but you can see currosion, under them and a spot that is always slightly damp, (obviously where it keeps dripping)
and i now i t wont help to make it preform in any way making it shorter i just dont wanna measure the hose, so if it was smaller it wouldnt matter.
also noticed my rad light is always on, ive never over heated or heated up faster than normal so im not concerned, assuming its low levels seeing as i am filling it a lil once a week
Old 11-12-2009, 05:55 AM   #4
The low coolant light's sensor is in the coolant overflow/reservoir. If that empties then you'll get that light; Naturally, it will keep emptying if you've got a coolant leak somewhere in the system.
Old 11-12-2009, 01:43 PM   #5
thanks ill fill the reservoir/ overflow, didnt think the sensor would be in there...
Old 11-12-2009, 07:15 PM   #6
Yeah, not the greatest place as it requires the cooling system to cool down enough to suck from the reservoir before you know it's low.
What I wish we had was an oil level sensor.... I've thought about adding one.
Old 11-17-2009, 03:48 PM   #7
that would be fantastic, considering my oil sensor is my noes atm.
Old 11-17-2009, 07:43 PM   #8
I think the 1JZ-GTE had one... not positive. Yeah, it'd be nice, but I'd still be checking my oil constantly; I'm just paranoid about that.
Locating Boost Leaks slader99 MKIII Supra 5 05-21-2008 01:12 AM
Oil leak(s) mattapo MKII Supra 3 12-21-2006 08:20 AM
Targa top leaks!!!! 90' turbo supra brandonsupra MKIII Supra 0 10-23-2006 08:04 PM
Targa driver side leaks when it rains!! Ahmad88 Exterior , Interior, and Detailing 5 07-21-2006 02:49 AM
Oil leaks on turbo Sath Non-Generation Specific Questions 0 12-04-2005 05:48 PM
