Old 11-03-2009, 08:38 AM   #1
jdmmilhouse
jdmmilhouse's Avatar
jdmmilhouse is on a distinguished road
Default NEED HELP! breaks up under boost!
i just bought a 89 mk3 turbo stock except for hks turbo back....
problem is that when i get into boost it breaks up ,miss fires...vacume leak?
any suggestions ? thanx!
jdmmilhouse is offline   Reply With Quote
Old 11-04-2009, 02:25 AM   #2
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
my 1j did that for a while, how's your intercooler? Also, you should think about checking your timing and make sure your using at least 91 at the pump. I don't think a vacuum leak would cause that.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
Old 11-04-2009, 02:52 AM   #3
Let's try to keep all the discussion for this problem in ONE thread.
http://www.toyota-supra.info/forums/...der-boost.html
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
Wont accelerate under boost, misfires, backfires, and wont idle Andrew - turbo a MKIII Supra 1 07-24-2009 01:39 PM
help? engine breaks up when in boost skadaloz MKIII Supra 2 06-02-2009 06:54 PM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
