Old 10-31-2009, 01:54 AM   #1
clarkrc82
clarkrc82 is on a distinguished road
Default High Idle, exhaust man glowing red
So just replaced bhg on buddys 88 n/a. It fired right up, but it idles around 2000rpm. Got it to idle around 1000 rpm and noticed the exhaust man glowing red? Checked all the wires and vac lines averything is good?
clarkrc82 is offline   Reply With Quote
Old 10-31-2009, 02:07 AM   #2
Check the mechanical and ignition timing... could be very retarded.
I just sent this to another guy a week ago:
Setting timing (both mechanical and ignition) in order:
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=29
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=30
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=19
http://www.cygnusx1.net/Supra/Librar...aspx?S=IG&P=20
When setting timing with the timing light the TSRM shows a SST (Special Service Tool) for jumpering TE1 and E1… just use a piece of wire or a paper clip. You MUST jumper those two connecters when setting the spark advance.
Old 11-02-2009, 06:26 AM   #3
dannydavi
dannydavi's Avatar
Exactly what CRE stated above, I had fire shooting out the exhaust man today cause of ignition timing being off! just follow those things he sent you to the book and you'll be golden.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 11-03-2009, 02:52 AM   #4
clarkrc82
Cool thanks for you replies, im gettin a code 51 now so tomorow im going to check out the tps. the car has been sitting for a couple of years
Old 11-04-2009, 12:52 AM   #5
clarkrc82
The tps checked out ok. My buddy thinks it is the idle control valve, its supposed to make a clicking sound when you turn off the car but it doesnt?
Old 11-04-2009, 01:27 AM   #6
When checking for codes the A/C must be OFF and you musn't press the throttle, either of these will set a code 51.
A false A/C signal to the ECU will set the A/C idle-up in the ECU causing an increase in idle when it's not really needed. The A/C idle increase is only a bump of a couple hundred RPM, not 1300.... if you've still got an idle of +2000RPM quit dicking around with the TPS and ISC.
Code 51 has absolutely nothing to do with the ISC... is there some other reason you're worried about that right now? Often they don't make any ticking noise because they need to be disassembled and thoroughly cleaned out.
***None of these has anything to do with a glowing manifold.***
I'm getting a bit confused here.... care to clean up your own thread a bit and tell us what you did and didn't manage to fix and why you're looking at some of this new stuff?
Old 11-04-2009, 01:53 AM   #7
clarkrc82
ok, my buddy thought it was the isc, book says your supposed to hear a click.
The ac wasnt on and I was not pressing on the gas. The code 51 went away and its not flashing any codes right now. Its still runnin around 2000rpm, just found out the alt is bad, dont think that would cause the high idle.
The only thing I have fixed on it was the hg, and every other gasket that goes with it, I also replaced the knock sensor. Thats it.
This car has been sitting for 4 years and it ran great before the bhg.
There has been a couple of time when I start it up and it idles around 700rpm and the it slowly works its way up to 2000rpm, then it jumps back and forth from 1000 to 2000. the highest it has idled was 2800rpm. If I completely retard the dis it idles around 1400rpm.
Old 11-04-2009, 01:59 AM   #8
You went back and re-timed everything as detailed in the four links I posted? Or are you just "sure it's fine"?
So, the car got a BHG and sat for 4 years then? I sure hope when the HG went that no coolant entered the oil system... otherwise you may have more to worry about than just burnt valves.
Old 11-04-2009, 02:13 AM   #9
clarkrc82
it hasnt been timed because its idling at 2000rpm. cant time it when its that high.
Yeah the oil was mixed with the coolant. Its had 2 oil changes to clean it out.
No burnt valves either. No smoke, and this sounds dumb but for idling high it runs really smooth, no vibrations and it doesnt miss fire. And when it does drop down to normal it runs smooth to.
I am completely lost with this car, Ive gone over every hose and electrical connection and everything seems good.
Old 11-04-2009, 02:49 AM   #10
Sigh.... you didn't REALLY read my post then.
I mean that I hope you thoroughly flushed it before the car was stored. If it sat for four years with the crank and bearings, etc. sitting in water contaminated oil then things could go bad real fast... rust does that.
If the manifold's glowing red think about what's happening to the valves...
I've tried... I'm done.
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
annoying high pitch squeal at idle oowee623 MKIII Supra 2 06-04-2007 03:02 AM
'92 7MGTE- high and unstable idle liona MKIII Supra 7 02-04-2007 03:18 AM
High idle nickvash0104 MKIII Supra 21 07-13-2006 05:14 AM
