Old 10-29-2009, 08:36 PM   #1
sd88supra
sd88supra is on a distinguished road
Question auto to manual tranny swap
I looked for related threads regarding issues when doing the swap, but the only one I found concerned the ECU.
First, a little background info: I just bought another Supra! '88 N/A auto with targa. I decided that I can't keep both (in college), so because I could never find an N/A 5spd w/ targa I decided to keep the auto and do a tranny swap (aside from the fact that the auto is much better taken care of, and I'd prefer a targa over TEMS).
Can I swap the trannies on the cars with no problems? My 5 speed would become auto and the auto would become a 5 spd. Input appreciated.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
sd88supra is offline   Reply With Quote
Old 10-29-2009, 08:42 PM   #2
Krem
no, it's not a straight across swap... there are things that need to be done, which I'm not 100% on.. I do know wiring of some sort must be ran to add a clutch.. possibly a sensor?
I also understand that the radiators are different between the cars. The Auto's radiator should have a built in cooler for the transmission fluids whereas the manual one does not. So might want to swap those with the transmission..
Wish I could help more, but I'm a newb that can do brake jobs and replace small components.. I'm no where near the level of expertise to swap out engines, trannies or any other major component for that matter. However, now that there's a reply to this thread, maybe you'll find the true answers you seek.
Old 10-30-2009, 02:34 AM   #3
Krem's about on target... the hard part isn't moving the 5 speed to the car with the auto, but moving the Auto to the car with the 5 speed will most likely suck. I don't think the 5 speed has a chassis harness for the automatic ECU (I know mine doesn't, so, you can probably add pulling the dash, center console, steering wheel out of BOTH cars... check ALL of the sensor and control locations before beginning work on this project. Along with swapping the radiator (piece of cake), you'll need to swap over the hard pipes for the transmission cooler too.
I'm not certain if the Automatic tranny wiring is in a separate harness or if it was a different chassis harness altogether, so check and double check before starting.
You DO have to swap the ECU's as well, so, if your other Supra is newer than '88 you're kind of screwed... unless you feel like doing some hacking to both chasis harnesses.
Have fun.
Personally, I'd sell both and find a nice 5 speed turbo MKIII... they almost all came with the sport roof.
Old 10-30-2009, 04:52 AM   #4
Beals
Beals is on a distinguished road
This is the current list I got for making my automatic a standard instead:
-Transmission Swap
Manual Gearbox + Bellhousing + ECU
450$
5 speed conversion pedal set
270$
Clutch Master + Slave Cylinder + Hose
150$
Spedometer Cable
100$
Stage 2 Clutch Kit
425$
DriveShaft
415$
Shift Boot + Short Throw Shifter
300$?
-Total:
2110$
Just wondering now that I read about the radiators does that apply to me?
Beals is offline   Reply With Quote
Old 10-30-2009, 07:26 AM   #5
You're fine with the radiator. It's when you're adding an auto to a 5 speed equipped chassis that you need to add cooling for the auto. Just plug the ports on the lower end tank of the radiator.
Old 10-30-2009, 07:23 PM   #6
Beals
Alright thanks, I might just end up buying a cheap rad to replace the stock one anyways just to prevent any leak issues.
Old 10-31-2009, 03:50 AM   #7
86.5supra
86.5supra is on a distinguished road
I did this swap in an 86.5 (went from auto to 5spd and 7mge to 7mgte in my first car) It took about a weekend but i used to work for toyota so that def. helped. I would look for a supra that has been hit in the side or the rear to get the parts.
86.5supra is offline   Reply With Quote
Old 11-24-2009, 06:01 AM   #8
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
-Transmission Swap
450$
270$
150$
Spedometer Cable
100$
Stage 2 Clutch Kit
425$
DriveShaft
415$
300$?
-Total:
2110$
sorry to jack your thread but i was just getting some info.
do you really need all of this to swap the auto out? im looking to do the same and i found a w58 i want to put in. im not looking for any performance upgrades. what do i need to just have the swap done?
cvbikeguy is offline   Reply With Quote
Old 11-24-2009, 06:05 AM   #9
The component list is fairly accurate but you don't need to spend nearly that much. You don't need a M/T ECU for example, the A/T ECU will work fine. You do need the complete tranny, driveshaft, pedal set, flywheel and clutch, clutch master cylinder and hoses. Most of the parts you can get used and for pretty cheap if you pull them yourself at a salvage yard.
Old 11-24-2009, 06:10 AM   #10
cvbikeguy
cvbikeguy's Avatar
cre your amazing!!!
this guy down south is selling a w58 for $150 and i think that isnt too bad right? and if i can get the rest of the parts for fairly cheap then maybe i will do the swap while im doing my head gasket?
ive had this car for 2 days now.... maybe im biting off more than i can chew?
What is involved (all parts, labor, price) in auto to manual swap??? the t3d MKIII Supra 1 01-18-2007 03:01 AM
Difficulty of changing tranny from auto to manual vas85 MKIII Supra 2 06-03-2006 08:30 AM
auto tranny but want manual supraboy8809 MKIII Supra 1 01-17-2006 11:36 PM
MKIV auto to manual swap?? awd4g63tsi MKIV Supra 0 10-24-2005 08:46 PM
