Old 10-25-2009, 03:54 AM   #1
suprajim
suprajim is on a distinguished road
Default Where is this hose supposed to lead to?
Ok, first let me apologize for my terminololgy....still learning the in's and out's of this car. So, I recently bought my 92 Turbo and was looking under the hood and noticed that there was a straight metal tube coming from the stock bypass valve and the other end was not hooked up to anything. So I looked at a few photos online and discovered that it should be connected to the top of the intake manifold (two red arrows in photo should be connected). However, there is another small metal tube with a bend at the end of it (see yellow arrow pointing to it in photo) that was hooked up to the manifold instead. My question is where SHOULD the tube with the bend be connected to? I have looked at photos and saw a hose coming up from somewhere below or next to the engine, but I don't see anything like that on mine. Please help!!!
ID:	2520   Click image for larger version
suprajim is offline   Reply With Quote
Old 10-25-2009, 06:28 AM   #2
If the BPV wasn't connected I'd inspect the turbo for any signs of damage.
The straight line is supposed to be connected to the BVSV and the other end to the TB port you show.
The BPV is supposed to connect to the bent line and the the other side which you have marked with the yellow arrow runs to a hard pipe lower down.
These diagrams show the vacuum lines you need:
http://www.cygnusx1.net/Supra/Librar...spx?F=1708&P=3
http://www.cygnusx1.net/Supra/Librar...spx?F=2211&P=2
Old 10-25-2009, 10:57 PM   #3
suprajim
Thanks for the help cre. So, it looks like the prior owner connected the wrong tubes, so I will switch those out. The other end of the curved tube was connected to the BVSV. However, I looked again and still could not see the hard line (22205 in diagram) that the tube from the BPV should connect to. Looking at the diagram from the TSRM, it shows the the hard line leads to a hose (22230w). Where does that hose connect to? I'm not sure if the hard line is the only thing missing or I need to get more parts. I am making a list of all the parts needed so I can order them all at one time. The turbo seems fine from what I can tell, no shaft play or anything. But now I'm nervous about any other damage that may have been done.
Old 10-26-2009, 01:51 AM   #4
If you look at the first diagram it shows the bent line with no connected hose. Below the intake manifold it shows one of the nipples of the hard line assembly with no hose connected. I *think* I recall that being the connection you're looking for.
I don't have a GTE and haven't worked on one in a while (not the intake anyway) so I'm not 100% sure. I will call and see if one of the guys I know locally with a GTE is willing to go poke around under the hood and check for me... dunno how likely that is tonight though.. the weather's crap.
Old 10-26-2009, 01:55 AM   #5
As for your concerns about things being messed up. Pull and read the spark plugs for signs of running lean and excessive heat; and do a compression test.
Old 10-26-2009, 03:36 AM   #6
Okay, my good friend Andy (helped me turbo my N/A recently) bought himself a GTE a couple weeks ago and was good enough to go digging under the hood for me. It does connect to the hardpipe I suggested earlier. I drew a picture, but the crayon just wasn't doing it for me.. so I had my pug make this diagram for you instead:
Name:	BPV piping.jpg
I hope this helps get things back in order.
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
Sm Vac Hose Under Accordian Hose Chromemoly MKIII Supra 3 07-03-2009 01:19 AM
Silicone hose in EGR lines? Paul_NJ MKIII Supra 3 04-14-2009 04:17 PM
Picture? Power Steering pressure hose ptomko MKIII Supra 4 10-08-2008 02:19 PM
