Old 10-19-2009, 11:27 PM   #1
dupra87
dupra87 is on a distinguished road
Default Hids?
Has anybody tried to put hids in an 87 supra do u need a relay to make them work or should it just be plug and play
dupra87 is offline   Reply With Quote
Old 10-20-2009, 12:58 AM   #2
corrosivecopper
corrosivecopper is on a distinguished road
The bulbs definately don't just plug in. The best thing to do is get a kit that has everything you need, relays, modules and all. It's a different system than the regular setup on the car, especially since these Supras have sealed beam headlights, unless the conversion to H10 bulbs (if I remember right) was done with a different kit.
corrosivecopper is offline   Reply With Quote
Old 10-20-2009, 02:23 AM   #3
Yup, buy a universal kit and get some Hella E-code enclosures. The enclosures ensure the light has the legally required cutoff (so you're no blinding other drivers and don't get hit head on) and they provide MUCH better light distribution than any cheap "crystal" housings you'll find... plus, like I said, the proper cut off is a federal regulation and tickets suck (especially ones you can't fight and win). There are plenty of kits out there, a few of the vendors over on SM sell them, IIRC; and I'm sure at least one of the vendors here can probably get some: http://www.toyota-supra.info/forums/authorized-vendors/
Old 10-20-2009, 02:47 AM   #4
dupra87
Default hids
i aready got a set but they didnt come with any relays. so i put them in with out and no lights. im sure they need one dont think the old mk3 can surport the amp there. just wanted to see if anyone else has ran into this thanks though
Old 10-20-2009, 03:22 AM   #5
Yes, you do need a relay. Supply the inverter directly from the alternator via a relay and trigger the relay with the old headlight line. Don't forget to install an inline fuse (I would think a 40A would do).
HID's for MKIII FLASupra MKIII Supra 2 11-22-2009 01:38 PM
HIDs for MK2 1984 supra itzyohomee_D Non-Generation Specific Questions 2 03-18-2007 12:01 AM
