Old 10-08-2009, 04:34 AM   #1
kelloggs067
kelloggs067's Avatar
kelloggs067 is on a distinguished road
Default help with tires
i have stock rims on my 92 and i was wondering what the widest tire i can run on the back of the car heres a pic of the rim also i would like to know the bolt pattern of it to
kelloggs067 is offline   Reply With Quote
Old 10-08-2009, 05:02 PM   #2
TurboSupera
TurboSupera is on a distinguished road
Those aren't stock for an MKiii, I believe. Correct me if I'm wrong but those are from an MKiv and are they 16" or 17"? Bolt pattern should be 5 x 114.3. I have a set of those rims (16" non-turbo) on my MKiii and I'm running 225 in the front and 245 in the rear. Personally I wouldn't go wider than 225 in the front and I might go with a 255 in the rear, when I need to change them.
TurboSupera is offline   Reply With Quote
Old 10-09-2009, 12:31 AM   #3
kelloggs067
ok i just got it like about a month ago so i am not to shore on alot for it i know hondas good but they are 16 by 7 thanks alot i am keeping smaller width on the from and wider in the rear thats what i was going to do but i did not know how wide in the rear i could go
Old 10-12-2009, 10:24 PM   #4
Supra_Newb
Supra_Newb's Avatar
Supra_Newb is on a distinguished road
Yeah, stock would be R16/225. As for max width on the back probably want stick with 255. My stock tires cost me $120 a piece, because the 225 width is a "special order tire". I'd have no idea how much 255's would run you.
MKIII
7M-GE
Automatic
Supra_Newb is offline   Reply With Quote
Old 10-13-2009, 03:36 PM   #5
TurboSupera
Wow, really?! I just changed my fronts about 4 months ago and my tires were only $89.00 a piece. I guess it depends on the tires, but $120.00 is still expensive to me. In California, 225s are not a special order here. Have you ever tried tirerack.com?
Old 10-13-2009, 03:47 PM   #6
Supra_Newb
Supra_Newb's Avatar
Nah I haven't I live here in Nebraska, and from what it sounded like at 'Walmart'( I know :*( ) They have to special order tires as wide as or wider than 225.
MKIII
7M-GE
Automatic
Old 10-14-2009, 04:36 AM   #7
kelloggs067
i would try tirerack.com i got prices and the tires i wanted i got 2 225's and 2 245's and 2 255's for the track and still with shiping cheaper then my store i work at
New Tires! 97SupraTT Non-Generation Specific Questions 0 10-03-2009 01:11 PM
Has anyone purchased tires from these sites? Chambers MKIII Supra 7 08-16-2007 03:27 AM
New Tires scruffboy Non-Generation Specific Questions 3 12-08-2005 12:39 AM
