Old 10-07-2009, 07:34 PM   #1
twan
twan is on a distinguished road
Default fog lights wont work!
my 1988 na will not turn fog lights on. i try it with the headlights on and off and still nothing. all fuses are working in the drivers kick panel and under the hood. i swapped all the relays around in case one was broken and nothing. i took apart the fog lights switch and everything is working. i stick a ohm reader in the fog light fuse slot and nothing! there is no power to the fog lights for some strange reason. i just bought it so i dont know what the last guy did. i am thinking of running two wires straight to the switch and adding a fuse somewhere under the hood. will this work?
twan is offline   Reply With Quote
Old 10-08-2009, 02:23 AM   #2
Busted Knuckles
Busted Knuckles's Avatar
No. the circuit running to the switch probably can't handle the load. The fog lights run off a relay under the dash. Here is a link to directions to properly rewire the foglights to the switch. http://www.supraforums.com/forum/showthread.php?t=169197
Make sure the relay is working before you cut any wires.
Old 10-08-2009, 02:30 AM   #3
Busted Knuckles
Here's a good photo page of the re-wire with a good shot of the relay.
http://gallery.sanitylapse.com/v/sup..._9406.jpg.html
Old 10-08-2009, 10:23 PM   #4
twan
sweet thanks man!
Old 10-09-2009, 03:31 AM   #5
twan
crap it didnt make a difference! i even read the end of the link to the forum and it said for 1988 supras u have to connect the new fuse to the red-yellow wire instead of the red-black wire. i give up...
Old 10-10-2009, 11:34 AM   #6
Busted Knuckles
Did you check if the relay works before you did anything else, as I suggested? If the relay is bad, the re-wire will not work. Also, the directions said to verify the wire functions first. You'll need a multimeter or test light.
The re-wire needs the high-powered side of the relay to also be powered. You may need to also cut this wire and connect it to a new fused circuit. Myself, I'd run a new line from the battery, fuse it at the battery, and run it to the high powered side of the relay.
Old 10-10-2009, 08:19 PM   #7
twan
hey yeah i checked the relay and even swapped it with the defogger. so then i went to parts source and got a "mini-add a circuit" where u take out a fuse and replace it with this thingy that has two fuse slots and a 12v wire coming out the side. so now i just to to check to see if i got the high power wire going from the fuse is going to the relay. i do remember it being the thicker wire of the 4 and it was red with yellow stripe.
and where do i hook on my ohm reader? if i knew what all eight wires did i prob would have this tackled by now lol.
thanks for the help so far!
Old 10-10-2009, 08:21 PM   #8
twan
Old 10-11-2009, 03:17 AM   #9
Wiring diagram: http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=076
That diagram is for a later model, as you've noticed, the wiring colors vary, but the routing is the same.
In stock form, the fog lights are are routed through the headlight switch (has it's own contacts, so a damaged switch is possible) thus requiring the headlights to be turned on for the fogs to light; the fog light switch; and the fog light relay.
If you do find that the relay is closing when the aforementioned requirements are met, but still no fogs, test for voltage at the foglight housings... it could be bad bulbs or grounds.
And it's not an ohm meter... an ohm is a measure of resistance and in this case such measurements would do you no good. For this you'd be using a volt meter or (more likely) a multi-meter (rather commonly referred to as a DMM - Digital Multi-Meter).
Also, be careful with the stock relays, they're not always interchangeable and you could damage something you don't want to pay to replace. They're not like Bosch relays which are pretty much standardized (except for a few uncommon types).
head lights dont work. 4runninghank Non-Generation Specific Questions 0 12-18-2006 04:00 AM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
Brake lights dont work ! 88supraTony Non-Generation Specific Questions 10 03-17-2005 05:41 AM
