Old 10-01-2009, 05:22 PM   #1
86.5 7MGE
86.5 7MGE's Avatar
Question Brake loss at high speeds
Ok so yesterday I was driving back home and as I'm going about 65mph+ I go to slow down and my brakes feel spongy real soft. That morning I didn't have any problems with my brakes. As I'm driving through town this morning I have nice firm brakes about 30mins later when I enter the freeway and I go up to 75mph+ I had to stop quickly when a car cut me off and to my surprise yet again no brakes, as the pedal traveled from about an inch from the floor I could feel the front ones engage and not the rear with loss of pressure. I got out when I stopped and check my fluid level and it's within the specified range between min and max. Can someone help me out on this? Thanks for all your helpful inputs.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 10-01-2009, 06:49 PM   #2
2jzmaestro
2jzmaestro is on a distinguished road
it sounds like a busted brake line
Did you ever find any brake fluid under your car?
Have your changed your brake fluid?
Or do you have some crappy brake pads those are bound to screw you over
more information please
2jzmaestro is offline   Reply With Quote
Old 10-01-2009, 07:03 PM   #3
86.5 7MGE
86.5 7MGE's Avatar
No didn't see any brake fluid under my car. Haven't done anything with the brake fluid except check the level of it maybe two or three times since I purchase the car. I changed out my front brake pads at the begining of this year I believe and haven't got to the rear ones yet. I purchased them from a OReilly's can't remember what the brand was exactly, but can get that once I get home this evening.
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 10-01-2009, 09:15 PM   #4
Krem
Something similar happened to me in an old chevy I had... was doin about 75-80 down the highway and when I went to exit, I came up on a 25 mph, u-turn off ramp... I applied the brakes and foot went completely to the floor... I repeated the process a few times and finally built enough pressure to slow for the turn (basically pumped and bled the brakes)... the next morning, I had brake fluid flooding the well of my right front wheel. :\.. busted brake line... The trip home (about 105 miles) was driven at no more than 45 mph, with emergency flashers all the way... had to use my gears to slow and stop the car in the city limits... was not very fun.
If you don't have any cracks in the brake line, I'd have to wonder about your master cylinder.. perhaps it's not pushing the fluid like it should..
Old 10-01-2009, 09:42 PM   #5
2jzmaestro
use this website and try to see what the exact part is if you can, itll make it much easier for everyone to help you diagnose the problem
http://toyotapartszone.com
hope it helps!!
Old 10-01-2009, 10:01 PM   #6
86.5 7MGE
86.5 7MGE's Avatar
Ok thanks Krem and 2jzmaestro for all the input I'll check to see if I have a bad brake line some where n go from there I'll keep you guys updated on the search.
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 10-02-2009, 05:57 PM   #7
TurboSupera
TurboSupera is on a distinguished road
How about brake fluid cavitation? It appears that this happens when the car is at higher speeds and when more is required of the brakes, right? The cheapest fix/diagnosis I can think of is to bleed the system with some good quality brake fluid and see if this still happens. Otherwise I think you're looking at a failed brake master cylinder or brake booster.
TurboSupera is offline   Reply With Quote
Old 10-03-2009, 05:05 AM   #8
86.5 7MGE
86.5 7MGE's Avatar
Ok I'll look into that thanks
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 10-03-2009, 11:37 PM   #9
86.5 7MGE
86.5 7MGE's Avatar
The brake pads that I put on in the front are Raybestos; I'm going to put some on the the back and check my lines for holes, and my caliapers to see if they need to be replaced.
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 10-04-2009, 06:19 AM   #10
Supra_Newb
Supra_Newb's Avatar
Supra_Newb is on a distinguished road
Also, you might want to check out your bleeder valves, I just changed a caliper and break pads for the rear, it freakin sucked and finally when I got done, my breaks would go right to the floor occasionally, turned out i didn't close the valves all the way LOL, sorreh for my stupidity.
MKIII
7M-GE
Automatic
Supra_Newb is offline   Reply With Quote
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
