Old 08-26-2009, 10:27 PM   #1
*D-Joker*
*D-Joker*'s Avatar
*D-Joker* is on a distinguished road
Default Brake Warning Light on dash!...
My brake warning light on the dash is on...it has been like that since i got my car...
i jus put new discs and pads on the front, n i bled all the brakes...but the light is still on
...does any1 know y?... is there are failure with the sender or somethin?...i heard one guy say that water leaks around his back window and it got into the sender at the back lights and he has got a problem with the warning light...could that b the case here aswell???
*D-Joker* is offline   Reply With Quote
Old 08-27-2009, 01:32 AM   #2
Busted Knuckles
Busted Knuckles's Avatar
Is it the tail light warning or the 'BRAKE' light? I had problems with my tail light warning because of a bad ground back there. But, if the 'BRAKE' light is on, then there is a problem with the hand brake sensor or the brake fluid level sensor. Both of these will turn that light on.
Old 08-27-2009, 03:29 AM   #3
*D-Joker*
*D-Joker*'s Avatar
well im not to sure...it is a top view of a car with a few lines around the back of the car pic...
my friend said it was the 'brake' light...but i think i agree with you on it being the 'taillight' light...cause i thought it looked strange for a brake warning light
...so if it is the taillights that hav a bad ground...wont that actually effect the lights themselves???...and did you run a new earth wire 2 fix the problem?
...but if it is the handbrake sensor...is it hard 2 replace/fix???
Old 08-27-2009, 06:27 AM   #4
Igknyte
Igknyte's Avatar
Igknyte is on a distinguished road
its not the anti-lock light is it?
Igknyte is offline   Reply With Quote
Old 08-27-2009, 11:57 PM   #5
*D-Joker*
*D-Joker*'s Avatar
ummm i dunno...as i said...i only just got this car, i showed my brother last night and he said it was the 'taillight' light.
all my other cars have been like pre-1970's lol...n they only have the oil light and engine light basically...so all these electrical gadgets are pretty new 2 me hahaha...sorry, jus gonna hav 2 bare with me.
what does the anti-lock light look like???
Old 08-28-2009, 12:31 AM   #6
That's the taillight warning light. All of the bulbs except the highmount brake light (or "third" brake light) are dual element bulbs. The warning light on the dash tells you if the brake elements do not offer the proper electrical resistance. If you have a bad ground, then it's possible that one or more of your brake lights are not illuminating, or not bright enough (can happen with a bad ground as well). These car's are notorious for bad grounds at the tail lights, so I'd go clean them up and inspect all of the bulbs.
Keep in mind there are 5 brake lights on these cars.
Old 08-28-2009, 12:53 AM   #7
*D-Joker*
*D-Joker*'s Avatar
oh ok...thanks heaps for that...
luckily my mate is a auto electrician lol...so ill go over to his n we will check for groundin problems, and check the bulbs.
thanks again mate
help with a dash warning light.. JZA70dood Non-Generation Specific Questions 3 09-28-2009 08:31 PM
Dash warning lights under hard acceleration Nato99 MKIII Supra 0 07-16-2009 11:18 PM
Warning light question scruffboy Non-Generation Specific Questions 4 06-11-2007 11:16 PM
dash light SAM MKII Supra 5 04-09-2006 03:50 AM
