Old 08-25-2009, 05:43 AM   #1
Kuanos
Kuanos is on a distinguished road
Default Noise near front of engine when clutch is engaged.
Really need help here. Just got an 87 Supra T last week. It has an RPS stage 3 clutch on it. When the clutch is engaged, I get a chirping sound - similar to a loose-belt sound. Previous owner thinks it's normal. Two ASE certified techs who work on imports think it's a bad crankshaft or something related. Of course, those techs don't deal with performance parts. Are they right? Any thoughts or advice?? Please help.
Kuanos is offline   Reply With Quote
Old 08-25-2009, 02:37 PM   #2
87mk111
87mk111's Avatar
It could be the throwout bearing. My old 'Teg did the same thing.
Old 08-25-2009, 03:13 PM   #3
kwnate
Crank walk. Heavy duty pressure plates cause problems.
Nate
Old 08-25-2009, 07:19 PM   #4
Kuanos
So, if I was to downgrade the clutch, would that fix the problem? Or is it something that is irreversible at this point? If so, how do I fix? Is the crank damaged?
Old 08-28-2009, 07:47 PM   #5
supradaddy0803
supradaddy0803's Avatar
I agree with Nate crank walk sucks and downgrading the clutch isnt going to help. You have done the damage now and seeing as the 7MGTE thrust main bearing is 3 peices on the top and bottom you have probably wore it out or just broken it. So if you take out the clutch then it will still do it. Sounds like you gonna have to look into doing the bottom end. But look into it there are way to check to see if the thrust bearing is bad but from what your telling us sounds like it I am sure if you ask any of the guys with high Horsepower they will tell you they have either run into this problem or were warned first and did all the stuff to the bottom end before getting that type of clutch.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
engine makes knocking noise.. 88WhiteMKIII MKIII Supra 4 06-10-2009 09:09 PM
85 engine noise long-cat MKII Supra 0 12-03-2008 08:02 PM
HELP! My engine just started a weird noise... idoke MKIII Supra 12 10-05-2006 05:06 PM
clutch noise gomezmk MKIII Supra 0 07-26-2006 03:45 AM
