Old 08-21-2009, 12:57 AM   #1
DJ 2501
DJ 2501 is on a distinguished road
Default Just bought a 87 supra no power in boost
Hello everyone I just registered and just got a supra today. Im very excited.
I traded my 92 civic for this beast. Has some mods hks hg and bov.
Something weird is going on though and being new to supras I need some help. First thing is the cel is on, I know how to pull the codes but can find any code lists to match them up to.
Second thing is the turbo spools fine and blows off and build pressure but when the boost kicks in the car bogs down and almost decelerates. Anyone have any idea as to what this could be?
I was heavy into honda's but its time to mod some real cars for once. I look forward to working on this car and learning and helping out around here.
DJ 2501 is offline   Reply With Quote
Old 08-21-2009, 01:37 AM   #2
DJ 2501
btw its a code 11 or a code 2 depending on how you read the chart. it blinked 2 longs and no shorts
Old 08-21-2009, 03:49 AM   #3
Kevin
when you jump in the diagnostics T and E1
it'll blink your codes. codes are double digits
btw there is no code 11. you should try again
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=26
hit next for the next 2 pages for all the codes
Old 08-21-2009, 01:17 PM   #4
DJ 2501
http://www.off-road.com/toyota/tech/codes/
Its def 2 longs and no shorts so im assuming it would have to be a code 11
Old 08-21-2009, 01:30 PM   #5
Kevin
did you try clearing it and then driving it and trying again?
Old 08-21-2009, 01:33 PM   #6
DJ 2501
No havent cleared the codes. On hondas you could do this by pulling the ecu fuse for 20 seconds. What is the process for supras?
Old 08-21-2009, 02:00 PM   #7
Kevin
i cant remember off the top of my head.. but all i do is disconnect the negative of the battery for 20 secs.
Old 08-21-2009, 06:21 PM   #8
btwilson86
Super Moderator
btwilson86's Avatar
You can also pull the EFI fuse for about 30 seconds or so.... I always wait a couple minutes to make sure it's cleared
Old 08-25-2009, 05:21 PM   #9
87mk111
87mk111's Avatar
That sucks about the turbo man. We should cruise sometime, I live in Ohio also.
Old 08-25-2009, 08:23 PM   #10
DJ 2501
Yea that would be cool. gotta pull the tranny out friday and replace some broken bolts. Where you located in akron?
Mkiv FAQ (Other Board) Critique/Discussion mrnickleye MKIV FAQ 7 03-03-2009 12:04 AM
bought a 93 supra steve7o2 MKIV Supra 2 10-05-2008 03:45 PM
1991 Non-Turbo Supra - Power Antennae Replacement Options unkymurch Non-Generation Specific Questions 2 04-29-2007 06:35 PM
