Old 07-14-2009, 02:21 AM   #1
Kevin
Default How to change e-brake cables
ok so i have replacement e-brake cables.. how do i go about changind them? do i start from underneath the car? or do i have to take apart the whole center console and backseats etc. someone point me in the right direction lol i looked at the tsrm and it didnt have it. i also have the haynes manual.. but that didnt help either.
Old 07-14-2009, 05:44 AM   #2
Beals
Beals is on a distinguished road
look underneath the undercarriage should find the cable near your tranny. Then just follow it to where you need to unbolt it.
Beals is offline   Reply With Quote
Old 07-16-2009, 01:43 AM   #3
Kevin
ok soo i look under there.. i dont see where it is lol. anyone got pics, diagrams or anything to help?
Old 07-19-2009, 01:34 PM   #4
Kevin
do i jack up the car and go from underneath or do i have to remove the interior?
Old 07-19-2009, 05:11 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
As you can see the cable is in three sections, assuming your replace all three, then it looks like you would only need to remove the hand brake cover to release the cable and not any other part of the interior . Looks like an adjusting nut & locking nut for the inner cable and some sort of clamp for the outer cable. The remaining removal would need to be done from underneath.
Old 07-19-2009, 05:56 PM   #6
Bill UK
AEM EMS
Bill UK's Avatar
Just found this from a right-hand drive supra, looks like you may also need to remove the centre console box.
Old 07-20-2009, 03:33 AM   #7
Kevin
Thanks bill. you've always been a lot of help
Old 07-13-2013, 04:44 AM   #8
brok
brok is on a distinguished road
Hey Im having issues with my e-brake but I dont know if its the cable or the actual brake. Whats happening is only one tire is disengaging when i turn the e-brake off, the other releases. The car sat outdoors for 3 years so im assuming its all rusted.
brok is offline   Reply With Quote
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
help with a brake issue tonystarks Non-Generation Specific Questions 3 05-21-2006 10:53 PM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
