Old 06-25-2009, 03:20 AM   #1
venomstreetmachine
Banned
venomstreetmachine is on a distinguished road
Default changed turbo and now the car wont start
I have been working on my 90 supra Turbo for a year now.
I changed the head and gasket ! decided to upgrade the exhaust manifold and turbo.
I also installed a fuel pressure regulator....
I need help !
Got everything mounted the car turns over but wont start !
1, the intercooler piping gets really hot just cranking the engine over !
2,Fuel Pressure only builds up when cranking
3,The car will start half arsed when I spray starter fluid pops and backfires!
Im dying to get this car going can someone help me or give me a hint
venomstreetmachine is offline   Reply With Quote
Old 06-25-2009, 11:34 AM   #2
mirage83
Any codes? Have you checked the mechanical timing as well as your CPS alignment?
Old 06-25-2009, 01:51 PM   #3
venomstreetmachine
Banned
Yep, Timing is spot on ! But I will check it again !
I have great compression !
Would you happen to know what the fuel Pressure should be? and if the EFI system should pressure up when the ignition is turned on? or when I turn it over?
Thanks for any help !
Old 06-25-2009, 03:34 PM   #4
mirage83
Fuel pressure for the GTE is supposed to be 33-40 lbs with the key in the ON position without the engine running. There are different procedures of checking the fuel pressure at idle, here's a link...
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=73
Old 06-25-2009, 04:58 PM   #5
venomstreetmachine
Banned
I appreciate the help ! But whats happening is... when I turn on the key nothing happens, the dash lights up but no fuel pressure ! I only get pressure when i am cranking.
Old 06-25-2009, 05:56 PM   #6
mirage83
Have you checked the EFI fuse? Is the fuel pump getting power?
Old 06-30-2009, 03:21 AM   #7
btwilson86
Super Moderator
btwilson86's Avatar
Fuel pump does NOT turn on when the key is just in the on position. It only starts pumping once the engine starts turning over.
It sounds alot like a timing issue... you said that the timing is spot on. Are you 100% positive that the cps was placed on the compression stroke and not on the exhaust stroke?
Old 06-30-2009, 04:09 AM   #8
Kevin
hey sorry to kinda hijack but how would u know if its on the compression or combustion stroke?
Old 06-30-2009, 06:46 AM   #9
jkendall86
jkendall86 is on a distinguished road
Default cps
check te cps...cam position sensor...take off the 3 screws on the side with the engine at Top Dead Center and check to see if the cam is in the right spot...check this out,
http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=22
jkendall86 is offline   Reply With Quote
Old 06-30-2009, 03:07 PM   #10
mirage83
You've got to jump a couple of wires to do the ON position test per the TSRM... +B and Fp iirc.
Tags
efi, fuel, intercooler, pressure, turbo
