Old 05-21-2009, 07:00 AM   #1
happysupraowner:)
happysupraowner:) is on a distinguished road
Default Confused
So like I posted before my car is ragging at the moment. Its smoking like crazy out the back, no smell to the smoke at all. I have no coolant overflow and my temp gauge does'nt go past halfway. What I want to know is if bad gas could possible cause the symptoms I'm having with my car? I bought gas at some out of the way mom and pop place and I think the gas had been there for years lol. I just don't know where to go with this thing. The compression test were fine on it. I just don't know what is causing it to smoke. It feels like it has lost a bit of power but other than that its fine. Thanks for any replies
happysupraowner:) is offline   Reply With Quote
Old 05-21-2009, 07:56 AM   #2
86.5 7MGE
86.5 7MGE's Avatar
Cool
I would check the oil just in case to see if it has any milky color to it...the 7M motors have a bad rep for BHG do to poor torquing by the manufactor... And the motor is great it will still run like a champ even though it does have a BHG...If not, then it could be a rich mixture causing the problem...also you can check your plugs to see if they are brown in color this will also let you know if you have a BHG, they should all look similar white and not brown if you do pull any with brown on it then that cylinder has been envaded by coolant due to a BHG...if I'm wrong I'm sure someone will correct me.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 05-21-2009, 02:00 PM   #3
Kevin
If you think it is bad gas. run it to empty. and put in Some premium Name brand gas. Make sure you use a good name gas.. many smaller gas stations have been known to water down their gas. I would recommend checking for bhg if that doesnt work.
Old 05-23-2009, 02:28 AM   #4
new supra guy
new supra guy is on a distinguished road
what color is the smoke white, gray, black, blueish tint, that can tell you what your burning.
new supra guy is offline   Reply With Quote
Old 05-23-2009, 06:39 PM   #5
happysupraowner:)
Its white with no smell at all. No plugs are brown. This car sucks lol.
Old 05-23-2009, 08:08 PM   #6
86.5 7MGE
86.5 7MGE's Avatar
Unhappy
Ok, then that means that your getting antifreeze in your cylinders some how, you might have a small leak in your head gasket and needs to be changed out. When the fuel mixes with antifreeze it produces a white smoke or steam from the exhaust. Check your antifreeze to see if you have any mixture of oil there in your coolant and check the oil filler cap and the dipstick also for any thing that looks brown or dark chocolate in color. But ultimately that's what's wrong is a BHG.
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 05-24-2009, 12:07 AM   #7
happysupraowner:)
I changed the oil when I started to first notice it, nothing milky, white or anything. I don't know what else it could be.
Old 05-24-2009, 12:15 AM   #8
craig
craig is on a distinguished road
i would put money on it being a blown head gasket. buy ARP headstuds to bolt the new gasket down and never have to worrie again
craig is offline   Reply With Quote
Old 05-24-2009, 12:44 AM   #9
happysupraowner:)
Yeah, its a bhg. I let her run just a bit ago for about 35 mins, and its started running very very hut. Gonna start taking the motor apart on weds. I know its gonna suck lol. I have no idea what I'm going to be doing lol. Its going to cost way to much to take it to someone. The only thing I'm worried about is the timing being a issue.
Old 05-24-2009, 04:07 AM   #10
86.5 7MGE
86.5 7MGE's Avatar
Wink
You should look up some threads about blown head gaskets in the forum there is one especially from Ihatehacks http://www.toyota-supra.info/forums/...ir-w-pics.html it's a long thread but pretty detailed along with pictures, that should get you started. And also if you have any more questions feel free to ask.
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Lost and Confused mkiiisupra MKIII Supra 7 12-30-2007 07:21 PM
Confused about gear box. plz help ASAP ADZ23 MKIV Supra 1 12-01-2006 12:18 PM
Can't adjust timing... Lunch2000 MKIII Supra 7 11-26-2006 04:09 AM
Man...Confused Poptart Non-Generation Specific Questions 2 06-27-2006 07:47 PM
confused localreeper Non-Generation Specific Questions 3 10-07-2005 12:25 PM
